Any source for Plymouth straight six (230) speed parts? #969563
04/08/11 08:34 PM
04/08/11 08:34 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Any source for speed parts regarding the Mopar inline sixer? 217 or 230?
Re: Any source for Plymouth straight six (230) speed parts? [Re: DusterKrazy] #969564
04/08/11 11:21 PM
04/08/11 11:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
www.rustyhope.com used to split intake and exhaust manifolds. I've seen heads and other stuff, but have no idea where a guy would get it other then maybe ebay. Speed stuff for a flat head are probably going to set you back some serious coin. Good luck. Gene
Re: Any source for Plymouth straight six (230) speed parts? [Re: DusterKrazy] #969565
04/08/11 11:51 PM
04/08/11 11:51 PM
Re: Any source for Plymouth straight six (230) speed parts? #969566
04/09/11 01:13 AM
04/09/11 01:13 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
http://www.edgyspeedshop.com/products.html
http://stoveboltengineco.com/
Mine:
That is cool! Tell me more about it! How good does it run?
Re: Any source for Plymouth straight six (230) speed parts? [Re: DusterKrazy] #969567
04/09/11 08:40 AM
04/09/11 08:40 AM
Internally stock except for a .060 overbore from who knows how long ago. Edmunds finned aluminum head I picked up at Hershey in the early 90's for $150 (don't expect to get one that cheap today, last one I saw on ebay sold for over $1000). Offy dual-carb intake (still available new from various vendors). Dual carbs/adaptors/air cleaners/linkage kit from Langdon's Stovebolt. Carbs are Holley/Webers that were OEM for a Ford Fiesta. Had to remove one of the three return springs on each carb to get the throttle effort right (way too stiff before). Single 2" exhaust with a 30" Smittie glasspack. Fluid drive converted to straight 3-speed stick and conventional clutch. Original 3.90 gears.
How does it run? What I've done is mostly for looks, but the dual carbs did perk it up - more than I expected. Dual exhaust would probably help, too. Runs good for what it is, but any new four-cylinder crackerbox will outrun it.
Re: Any source for Plymouth straight six (230) speed parts? #969568
04/09/11 06:57 PM
04/09/11 06:57 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
I can dig it. I have one that is .060 over but it is a fresh motor. Even though it has been sitting for a while. I Thought that it would not hurt to play with it some.
Re: Any source for Plymouth straight six (230) speed parts? #969569
04/15/11 11:31 PM
04/15/11 11:31 PM
OHIO
THE GLASS MAN Offline
OHIO
You have a good start with the flatty and all of it's goodies. You dumped the fluid drive, for the standard, which is good. Did you notic that when you shift into high gear that the car falls on it's face and eventually gets back into the power range? Put a 36-37 Mopar 3 speed in it. It is close ratio and you will whip those brand x 4 bangers. You will have to notch the bell housing and box it in , but the work will pay off, and you will have 3 on the floor instead of 3 on the tree.
Re: Any source for Plymouth straight six (230) speed parts? [Re: THE GLASS MAN] #969570
06/13/11 09:27 PM
06/13/11 09:27 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
How do you tell the difference between a 218 and a 230?
