Re: MOPARS at the Strip live feed!
[Re: J_BODY]
#969423
04/11/11 01:11 AM
04/11/11 01:11 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
ran my fastest time ever in the left lane today...
went 3 rounds in Super Pro..
car ran consist...except in round 3...dialed a 10.79 ...been running in right lane all day...got into left lane and ran 10.687...big break out.
got close in the run for the money...dialed a 10.77 and ran a 10.782...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#969424
04/11/11 02:19 AM
04/11/11 02:19 AM
Posts: 396 California, USA
Phil Saran
California, USA
There seemed to be alot of broken differentials this weekend and we were one of them. stripped all the teeth off the spider gears, time for a 35 spline spool and axles at a minimum. 67 cuda stroked R3 block about 650 HP. Just means it's time to spend more $$$.
I got to visit with Al, Chris and Billy. Saw lots of the guys on the board running their cars.
Phil Saran
Parker, Colorado
[Re: 70AARcuda]
#969425
04/11/11 02:23 AM
04/11/11 02:23 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Tony, by chance are you running the heads I ported on yet? Just curious, I'd like to know how it runs. Jason.
[Re: 70AARcuda]
#969427
04/11/11 03:03 AM
04/11/11 03:03 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Jason..those heads are still in the plastic bags that i picked them in...LOL
sometimes having too many project is not good...
Saw Tonya red light first round... DOH!!!
[Re: RobX4406]
#969428
04/11/11 12:15 PM
04/11/11 12:15 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Well two seperate times at the top of first gear my tires were spinning...That should not happen especially with a car that makes the power mine does. The semi final I tried my dardest to take out the wall at the 1000' mark when the car made a hard left turn, cost me the race as I had to lift being only a couple feet from the wall. In the semi's of Q16 three of the four cars did not get down the track, the only one that did was my opponent in a dragster. After the second semi when the AMX got crazy out of shape and almost hit the wall in the same lane I was in they decided to check the track. So draw your own conclusion. I should a few folks my RPM captures from a coupld of runs and we had some issues.
I was very dissapointed in the track to say the least. Can't say I was alone in those feelings. I am sure it was just the way my car is set up. We are not set up to run the car all out and it shows. I do it once a year at this event. I think this may be the last time I do however. If this is the way the track is gonna be then I am not interested. I know sometimes you have to race the track but just not interested in doing it at a once a year race. Although with the way the track was if I had the stop on it may have been uglier when I came off the stop. Oh well back to stop racing for me.
Someday maybe I will buy a converter and se what it can really do, three and a half seconds to gain 300 after the shift just dont cut it not to mention how slow it comes up off the line. To say it is tight is a bit of an understatement...
[Re: J_BODY]
#969431
04/11/11 09:29 PM
04/11/11 09:29 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
Both passes I saw Ted launch on were in the L lane. Car made an immediate right turn, the second worse than the first. Did note that most of the day when I checked in that the DA was around the 2400/2500 mark. That's pretty dang good air for Vegas .
Yep that's what happened and I have to blame the track prep, cause the car does not usually do that, well maybe a tad, but not so badd I am looking at the tree when I launch. All in all I did have a good time hanging and shooting the breeze with all the MOPARTS members, I seen a bunch and they are all GREAT!!
Diego
[Re: Leigh]
#969434
04/12/11 02:11 AM
04/12/11 02:11 AM
Al_Alguire
Las Vegas
Leigh, no worries. I assume you mean my last burnout in the Semis. Appears I have a line lock problem, showed up loading the car too. Just something to fix no big deal. I thought maybe I was in first gear when she would not move after the burnout. Car just would not roll after I eased up frm the line lock acting up. As for the track, hey. I was sitting under the tower to be the next pair of cars down the track when the snow began to fall IMO it is a shame that the best part of this event in my mind, the drag race suffered as it did from issues. Hope the event continues but not this way....... Tom turns out there really was not an issue. We thought maybe a clogged bleed, which it sort of was with a piece of junk actually sitting on top of it.
