Oil Filter plate gaskets for SB #96915
07/30/08 08:31 AM
07/30/08 08:31 AM
Anonymous OP
Anonymous OP
I am not going to use the right angle oil filter adapter on my 340. dont need it.
So I am going with the plate. Does this only use 1 gasket (the peace sign looking thing with an outer ring and an inner ring) or do you use a thicker donut type gasket for the center fitting?
also, which way does the fitting go on? meaty side in the block?
Re: Oil Filter plate gaskets for SB #96916
07/30/08 09:49 AM
07/30/08 09:49 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
one big outer gasket. no gasket under the center.
