WHEEL STUDS? #969110
04/08/11 01:03 AM
04/08/11 01:03 AM
California
493Dart Offline OP
493Dart  Offline OP
California
Hi, need to install longer front wheel studs on my 72 dart bracket car. Am running centerline 15x3.5 on 10 in.drums. Where I'm confused is the so-called "knurl" specs. Year 1 says should be .555,but can't find anyplace that sells them.any help greatly appreciated.
1972 Dart Swinger 493 1968 Sport Satellite 496 1965 Plymouth Barracuda 340
Re: WHEEL STUDS? [Re: 493Dart] #969111
04/08/11 02:09 AM
04/08/11 02:09 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
The .555 knurl may be the stock spec before swedging the studs in. The larger spec you see may be the size to use once you pull the old ones out, enlarging the hole due to not cutting the swedge interference. The stockers will not fit if you pull the swegies out forcefully without cutting the swedge down (or grinding the heads off and pulling them out the front, no damage there)
