fuel injection? Haven't done the swap to FI yet, but here is what I invested in for my truck 360 fuel system:
Holley 670cfm truck Avenger $400 + $9 for throttle lever adaptor. Then the carb didn't run right out of the box, so blew another $100 on:
$23 for accelerator pump cams,
$12 for vacuum secondary spring kit,
$9 each for power valves
$52 for a jet kit (or $7 a pair)
$12 each for discharge nozzels
$7 pair of 'blue' fuel bowl gaskets
$10 pair of metering block gaskets
Finally spent about $60 on a billet metering block, which made a big difference.
Used it to match up the restriction sizes, and when cleanong the Holley metering block, found left over debris in the jet wells from when holley made the metering blocks!
This dosen't even include the cost of the fuel system. I have an edelbrock 120 gph electric pump $160, and at least $200 on -6 AN fittings and braided fuel lines.
I spent $75 to chassis dyno with wideband O2 sensors, but if I wanted to install and monitor O2 sensors that would be more $$$.
So I probbably have close to $1,000+ in a carb fuel system that is really only tuned for a limited atmospheric conditions. Oops, forgot to include monies spent on filters and fuel pressure regulator....
FAST, Professional products and Holley all have 4bbl TBI kits for $2,000 or less.
The $1,650 Powerjection III #70026 is a complete kit with pump, filter, 750cfm tbi, wideband O2, regulator, pressure gauge, electronics, map sensor, etc.
Doing a Google search I found the polished kit even cheaper, #70027 for $1,497.76 at:
http://www.autopartsdealer.com/professio..._content=rank13
