T66 i can get a good deal..i think?? Need Advice Quick! #968645
04/07/11 05:44 PM
04/07/11 05:44 PM
Wisconsin
moparkid88 Offline OP
Wisconsin
My new neighbor moved in and we got to talkin and he has a t66 that he was going to put on his older toyota supra and he is looking to sell it. I am going into uncharted territory in my skills here and i would really love it to do a single turbo smallblock i was thinking thow it on a 318 till it blows as im building a 360. I dunno what to look at or look for but he says it made like 600hp on the dyno but can anyone help me..Oh yea he wants 200 bucks really neeeds to seller....Its a precision..also says .68 i think ill look again..
Re: T66 i can get a good deal..i think?? Need Advice Quick! [Re: moparkid88] #968646
04/07/11 11:14 PM
04/07/11 11:14 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
As long as it is a Ptrim exhaust it will work fine for a mild 318.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: T66 i can get a good deal..i think?? Need Advice Quick! [Re: CW25] #968647
04/08/11 08:33 AM
04/08/11 08:33 AM
Wisconsin
Wisconsin
How do i id a p trim??
Re: T66 i can get a good deal..i think?? Need Advice Quick! [Re: moparkid88] #968648
04/08/11 04:52 PM
04/08/11 04:52 PM
IL
furious70 Offline
furious70  Offline
IL
For $200 for a PT66 if it looks ok and you can spin the shaft without it rubbing buy it and worry about whether it works for you later. You should be able to flip it no problem.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: T66 i can get a good deal..i think?? Need Advice Quick! [Re: furious70] #968649
04/08/11 05:50 PM
04/08/11 05:50 PM
Wisconsin
Wisconsin
i talked to another kid i go to tech school with and he said play in the shaft is ok if its a ball bearing turbo as long as it dont rub, i checked it and it has some play and it doesnt rub so am i good??
