Wish pics of porting jobs on BB heads, stock valves #968457
04/07/11 02:46 PM
04/07/11 02:46 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Since I have found the templates SIMPLY DOESN'T WORK ( If I have to cut everything the template says me will be cutting the valve seats too specially in exhaust ports ), I went and made vertical grind job from inner valve seat edge up to bowl, blending the valve guide area to this.
Can I see your jobs on this ? specially intake. I'm afraid I could grind excesivelly on intakes ports and get really close to water passage areas making this vertical wall.
Re: Wish pics of porting jobs on BB heads, stock valves [Re: NachoRT74] #968458
04/07/11 03:21 PM
04/07/11 03:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
