Re: 2000 Dakota trans band adjustment specs?
[Re: JERICOGTX]
#967577
04/06/11 09:11 AM
04/06/11 09:11 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
4.7 will have a 45RFE trans There are no bands, or for that matter any adjustments.
If you are servicing it, make darn sure you replace the primary filter seal and that it gets seated correctly in the pump (There are two filters in there) if the seal is not seated it will suck air and cause all kinds of issues.
Rick
Blown71X V2.0 under construction
71 Cuda 383 4-SPD (maybe for sale)
2010 Challenger B5 Classic
[Re: Blown71X]
#967578
04/06/11 10:10 AM
04/06/11 10:10 AM
Posts: 10,032 MN
JERICOGTX
MN
So what needs to be done to these short of drining the fluid, and replacing the filter?
Thanks for the help Rick.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#967579
04/06/11 10:26 AM
04/06/11 10:26 AM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
So what needs to be done to these short of draining the fluid, and replacing the filter?
nuttin honey
[Re: JERICOGTX]
#967582
04/06/11 11:31 AM
04/06/11 11:31 AM
Blown71X
super gas
super gas
A tad North of Indy
That, for the most part covers it.
As I said there are two filters, a primary, which is what most consider to be a normal filter and there is also a converter outlet filter...It looks like a small screw on oil filter. You can use what ever you feel like on the primary, but please use a mopar for the outlet filter. There have been issues (even on the early mopar pieces) with converter drain back with that outlet filter. Current part number 5179267AC
Like I said above make sure you replace and get seated properly, the primary filter seal.
Use silicone on the pan....do not try a gasket, it WILL leak.
On those years, while you have the pan off, look up in there on the passenger side (just behind the screw on filter) on the valve body, you will see a thin metal plate bolted to the valve body (running front to rear) this is the accumulator pistons retainer. They are known to break the bolts off. This allows the piston(s) to come out and you will lose various gears depending on what comes out. Usually reverse or 3rd is the first to go (L/R and OD accumulators on the ends) 3rd is a fun one it will take off fine, once it sees a ratio error on the 2-3 shift due to the OD clutch not being able to apply it goes to limp, Limp mode on a RFE is 3rd.....You are not going anywhere at that point
If it is flat against the body it is ok, it will be bent out if any of the bolts break. There is a updated plate kit for this if it is broken.
Edit: one other thing, be carefull of the pan bolts, they are 6mm (8mm Head) and snap off easily, also will pull the threads out of the holes if there is silicone up in there Rick
