Pitted Valve Covers - Bondo? #966581
04/05/11 07:19 AM
04/05/11 07:19 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
Picked up a set of valve covers and had them blasted which revealed some pitting. I planned on fillin it in w/some bondo before painting. Will it hold up due to the heat of the engine?
Re: Pitted Valve Covers - Bondo? [Re: Pntastar69] #966582
04/05/11 08:07 AM
04/05/11 08:07 AM
Under My Car
Mopar_Country Offline
Under My Car
Never tried it, but when I did mine they had some minor pitting. I cleaned them real good and primed, went over them with a scotchbrite pad gently, primed again and painted. They turned out real nice for 40 year old covers.
Re: Pitted Valve Covers - Bondo? [Re: Pntastar69] #966583
04/05/11 09:45 AM
04/05/11 09:45 AM
crlush Offline
crlush  Offline
I've done it with bondo, held up fine, if you can try heavy priming the spots and then sand them down till smooth.
Re: Pitted Valve Covers - Bondo? [Re: Pntastar69] #966584
04/05/11 01:22 PM
04/05/11 01:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
works just fine.
Coming soon!!!!
Re: Pitted Valve Covers - Bondo? [Re: Pntastar69] #966585
04/05/11 01:23 PM
04/05/11 01:23 PM
Jacksonville Florida
elitecustombody Offline
bad idea, if I were to do anything like that, I'd use lead or some sort of two-part metal epoxy, JB Weld,e.t.c.
Re: Pitted Valve Covers - Bondo? [Re: elitecustombody] #966586
04/05/11 02:06 PM
04/05/11 02:06 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
this filler works, if you are interested. http://www.alvinproducts.com/Products/Products.asp?id=2
Re: Pitted Valve Covers - Bondo? [Re: Golden-Arm] #966587
04/05/11 02:19 PM
04/05/11 02:19 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
JB Weld is good to 500F, which is more heat than any valve cover will ever be exposed to. It doesn't feather out that great, but you can apply some primer over top of it and carefully sand the area a few times to smooth everything out.
Re: Pitted Valve Covers - Bondo? [Re: Neil] #966588
04/05/11 03:41 PM
04/05/11 03:41 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
it'll work, though I usually just use a few coats of heavy primer/surfacer (sanding between coats)
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Pitted Valve Covers - Bondo? [Re: DPelletier] #966589
04/05/11 06:23 PM
04/05/11 06:23 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
I used steel in a tube on my valve covers 8 years ago. Had a small dent. Holding up very well.
Re: Pitted Valve Covers - Bondo? [Re: superbeedave] #966590
04/10/11 04:55 PM
04/10/11 04:55 PM
SE Pa.
LimeliteAero Offline
SE Pa.
check this out Mark! Its what I will be using to bring my VC's back to primo condition.
Re: Pitted Valve Covers - Bondo? [Re: LimeliteAero] #966591
04/10/11 07:26 PM
04/10/11 07:26 PM
P
P
