1973 340 Choke Thermostat
#966073
04/04/11 08:24 PM
04/04/11 08:24 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
I'm looking to purchase a choke thermostat for a '73 340 Thermoquad. No idea what it should look like. I've been online to NAPA, Advance, and O'Reilly. Auto Zone seems to have the only one that is labled correctly, most will show a 340 2BBL application. This is a Duralast manufactured by Wells. Does this look correct? Web page http://www.autozone.com/autozone/parts/D...56_207659_8298_
Re: 1973 340 Choke Thermostat
[Re: Dave Watt]
#966074
04/04/11 08:52 PM
04/04/11 08:52 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
thats the one my BB 4bbls have and I think SBs are the same connects to this: welll actually thats double stage for BB... the SB uses single stage which are the same but without the ballast
[Re: Dave Watt]
#966078
04/05/11 12:01 AM
04/05/11 12:01 AM
NachoRT74
Valencia, España
is not REEAAALLY NEEDED OR MANDATORY due engine heats by itself the coil, but is an electrical assistant to shorten the choking time and really helps out.
the units with ballast sends two diff voltage sets what changes with engine bay temperature. ( double stage )
The units without that, has only one voltage level untill warms up ( single stage )
normally SB and /6 carries single stages
[Re: Dave Watt]
#966082
04/05/11 04:42 PM
04/05/11 04:42 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
73’ was the first year electrically heated choke springs were used for most engine carburetor combinations. The intent was to get the choke off quicker than engine heat alone could for the sake of meeting emission requirements of the day. If the choke spring pictured is correct for your application, the pic clearly shows it having a heating element, then a choke control was installed on your car originally (usually under a intake manifold bolt head, on the passenger side near the choke well). Unlike modern day aftermarket electric chokes, those heating elements draw close to 2 amps while in operation and was only required during the first 5-10 minutes of cold start, after which crossover heat keeps the spring relaxed. 2 amps added to the ignition run circuit, including the bulkhead connector and ignition switch. As mentioned, there were a couple different versions, with and without a by-pass resistor, and was later superseded to a solid state design around 77’ or so and continued on through to the end of carbureted engines. I believe Nacho’s point was if you go without the controller (don’t power up the heating element and crossover is open) there will be sufficient heat to open the choke, just later than originally designed.
[Re: NachoRT74]
#966084
04/05/11 05:07 PM
04/05/11 05:07 PM
Challenger 1
Cincinnati, Ohio
connects to this:
Are those available in the aftermarket? I'm thinking so. I have a few stock iron manifolds with those things still attached.
[Re: Challenger 1]
#966085
04/05/11 05:16 PM
04/05/11 05:16 PM
Posts: 4,587 St. John's Newfoundland
440newport
You can get a modern equivalent that works the same, but they don't look like originals.
[Re: Challenger 1]
#966086
04/05/11 05:17 PM
04/05/11 05:17 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
The picture the OP posted does not look correct for a 340, I used a 73 340 choke on my Duster with a TQ and the rod was straight. I got mine from Rock Auto. LINK I would also like to find out if the resister is available new, I need one for my Charger, and have had no luck finding one.
[Re: T2R9]
#966087
04/05/11 05:21 PM
04/05/11 05:21 PM
Posts: 7,365 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I found a resistor on E-bay but it was NOS and I didn't really want to spend that much.
I'm almost possitive the 4-barrel cars had an angled rod. The carbs are a lot wider so a straight rod wouldn't work.
[Re: Dave Watt]
#966090
04/06/11 01:40 AM
04/06/11 01:40 AM
NachoRT74
Valencia, España
Lets say the crossover is blocked off such as with the Edelbrock heads. After the car warms up, do you constantly power the choke thermostat to keep it open? Or will the thermostat burn up?
the power is an automatic feed from control unit as soon you start your engine ( key in run ). If wired like factory did, you don't control that, just ign switch and it decreases the power when engine temp is reached, thats the deal for the control unit. If wasn't in that way wouldn't make sense hook a control unit, instead wire the choke directly from ign switch
Hard to damage the choke really
LATER models ( the round ones ) were also used along with a three prongs oil sender switch, where the power to controil is turned on just when oil sender sense the oil, meaning engine is running. In that way you won't heat the choke just switching on the ign swithc at RUN without start the engine
[Re: 440newport]
#966091
04/06/11 03:50 PM
04/06/11 03:50 PM
Dave Watt
Atlanta Indiana
Can you tell us what make and model of car uses this style?
[Re: 440newport]
#966093
04/06/11 06:12 PM
04/06/11 06:12 PM
72roadrunnergtx
I would question referring to any of these variants as a "modern" equivalent. There was a later 70s design (button style),replacements are still in production in the aftermarket world. If you chose to go with the NOS versions of the original design, be sure to get a couple of spares, they didn't last long back then and won't last any longer now. The high current draw of the heating element burns the contacts to the point that current no longer passes through it at all. Careful describing the resistor as a ballast, it's simply a power resistor used originally to give some versions of the controller two levels/stages of power/voltage to the heater. The later button style controller had some versions having the power resistor connected as a by-pass. The contacts were either closed (providing full voltage to the heater) or when open, depending on engine temperature, would provide partial voltage, via the power resistor, throughout the remainder of the run cycle. Reminder, current aftermarket electric chokes don't pull anywhere near the amount of current these OEM heaters do and are designed to be connected to ign-run circuits full time. Any currently available aftermarket choke delay/timer controls will not likely handle the current load of the factory type heating elements for very long.
If your cross-over is blocked, like I found with the Edlebrock heads/six-pack set-up, you may need to run a by-pass design as I have described in the above link. I wouldn't run the full current of that heater though my wiring full time. Heating element is not likely to burn-up, the wiring, bulkhead connectors, ignition switch and it's connections likely will.
[Re: 72roadrunnergtx]
#966096
04/07/11 12:28 AM
04/07/11 12:28 AM
NachoRT74
Valencia, España
well last time I checked was functional... but it was long time ago... will check soon
[Re: NachoRT74]
#966097
04/12/11 11:23 PM
04/12/11 11:23 PM
Posts: 1,547 Puyallup, Wa.
Steve340
Puyallup, Wa.
This is the 340 one. Part # 4027793.
