Re: The Good, The Bad and The Ugly
[Re: dartman366]
#966052
04/04/11 09:24 PM
04/04/11 09:24 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
soooooooo,, when's the new bullit going to be dropped in the car??
I'm working on it Bill. I had to see what was salvagable from this pile first. I need some machine work, rods and a LOT of cleaning.
[Re: S/ST 3040]
#966053
04/04/11 09:29 PM
04/04/11 09:29 PM
Posts: 3,396 Pa
Hot 340
Pa
If you ever get enough water or fuel in a cylinder to hydraulic it, pull it apart and check the bearings. If it was real bad, it might bend the rod too.
That rod and journal got pretty hot. How do you figure it was a hydraulic issue?
[Re: S/ST 3040]
#966054
04/04/11 09:35 PM
04/04/11 09:35 PM
dartman366
Mt. Vernon, Ohio
Don't have much to offer but moral support, but if I can help let me know.
[Re: S/ST 3040]
#966055
04/04/11 09:43 PM
04/04/11 09:43 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
One thing comes to mind,................ KERRRR-SNAP!! You never did find that lucky coin I gave you back,did you??? Keith
[Re: Hot 340]
#966056
04/04/11 09:48 PM
04/04/11 09:48 PM
S/ST 3040
When an engine kicks over with a full cylinder, (previous firing piston, not starter) it deforms the upper bearing. It's just a matter of time before it spins the bearing.
[Re: S/ST 3040]
#966058
04/04/11 09:56 PM
04/04/11 09:56 PM
Dunnuck Racing
Northern Indiana
June will work good,I'm just about done testing this big block(may post some results tonight). I will have my 421 on here soon,I have some things to try on it,I may be consulting with you on some of them soon! Keith
[Re: S/ST 3040]
#966060
04/06/11 01:52 AM
04/06/11 01:52 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
That's not right. From the pictures anyone can CLEARLY see it was an oil pan failure.
[Re: B1KILLER]
#966062
04/06/11 06:02 AM
04/06/11 06:02 AM
Posts: 2,128 sweden
sshemi
sweden
[Re: 340RICK]
#966065
04/06/11 07:39 PM
04/06/11 07:39 PM
S/ST 3040
I would have expected 200 passes without taking it apart. I usually can't leave the engine alone that long. I will put main studs in it and have the main bores touched up while it's at the shop. Milodon 340 center sump pan for sale. 40 passes in a pump gas 340. Needs work.
[Re: S/ST 3040]
#966066
04/06/11 07:43 PM
04/06/11 07:43 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
I'm amazed at what the scat I beams can do. That's a revver! Makes me feel a lot better about using them in my 408. Here's to a speedy recovery.
[Re: Hitman340]
#966068
05/07/11 10:17 PM
05/07/11 10:17 PM
S/ST 3040
I picked up the block from the shop yesterday. It didn't require the sleeve. Another .020" honed from the bore cleaned it up surprisingly well. Only 2 visible "flicks" and well below ring travel. White specks are just lint. BIG 349.6" engine for 2011
