Six-Pack Upper Fuel Lines - Steel or Aluminum? #96588
07/29/08 01:17 PM
07/29/08 01:17 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Hey Guys,
I am going to get a new set of Upper Fuel Lines (Fuel Pump to Carbs) for a '70 440-6 setup. I noticed there are two choices for the stock setup look - Aluminum and Steel.
I believe my existing lines are aluminum (is this how they came from the factory?). What are the advantages of using steel lines -- I imagine they are stronger... any downsides? What do you guys recommend?
And are these stock-style lines (with the brass "T" connectors) the best way to go for a six-pack setup or have some folks used other setups they like better?
Thanks a lot!
Re: Six-Pack Upper Fuel Lines - Steel or Aluminum? [Re: stan1970] #96589
07/29/08 01:39 PM
07/29/08 01:39 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Stock ones are steel. I would want as stong as line as I could get in the area. The weight savings is only a couple of ozs., if that. Why go with aluminum??
Re: Six-Pack Upper Fuel Lines - Steel or Aluminum? [Re: BRawls] #96590
07/29/08 02:48 PM
07/29/08 02:48 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, just plain old steel, as were all Mopar hard fuel lines. Stainless steel is a common upgrade but not considered OE correct.
Re: Six-Pack Upper Fuel Lines - Steel or Aluminum? [Re: stan1970] #96591
07/30/08 12:49 PM
07/30/08 12:49 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Replace them. Check here, good prices (from another post on Mon, Jul 8, 2008)
http://www.herbsparts.com/products.asp?cat=102&pg=6
A True Hybrid: Burns Gas AND Rubber!
