Re: Magnum 5.9 distributor gear install/orientation
[Re: AtomicDog]
#965108
04/03/11 12:52 PM
04/03/11 12:52 PM
RapidRobert
Actually you can clock the inter gear anywhere as long as you put #1 wire on the particular cap terminal that this clocking locates the rotor under, but k.i.s.s. if your wires/firing order are already in the cap in the location you want em just clock it wherever it takes to place the rotor under the #1 wire otherwise if your starting from scratch(n) for standardization clock it so the rotor is forward and slightly toward the pass side (7 o'clock if you are standing in front of the car) and plug the #1 wire in that cap terminal and know that some dizzys have a way different dist bottom shaft tang location to top shaft rotor slot location (phasing) than other dists but the bottom line is where the rotor is pointing to & I would back the crank up slightly CCW to 10BTDC & turn the housing till the vac can is in the correct general location (has room to be turned each way) then line up the nearest reluctor tooth dead even w the magnet WITH the rotor under (or close to) the #1 cap terminal and the rotor to cap terminal phasing needs to be somewhat close & to check that make a mark on the outside of the dist housing for where the rotor is then set the cap on & check it (if the rotor is under/near the underside of the #1 cap terminal and vac adv will shift rotor phasing CCW (CW on a BB) slightly from that point (ie 8 degrees around the circumference for a can stamped 8 on the arm) and this rotor phasing (one of my Mopar obsessions) is diff from the dist bottom tang/top rotor slot phasing mentioned earlier. I am assuming you felt compression on #1 plug hole to verify your on compression rather than 6 and 12 o'clock (dot to dot) which'd put it on #6 firing EDIT (re)read the above post(s)& my info was for earlier stuff & may b out to lunch on the newer
[Re: Andrewh]
#965109
04/03/11 01:22 PM
04/03/11 01:22 PM
Posts: 859 VA
AtomicDog
VA
maybe you misunderstood.
With the rotor on the distributer lined up to tdc. See how the slot in the distrbuter is set up. front to back, left to right, some 45 degree angle.
The TDC mark/number 1 cylinder will proabably be 2 towers over from what will be the front post when the distributer is in the engine.
This will let you see how the gear you are dropping into the engine has to be aligned, for your distributer to sit in the right place at tdc.
I did not misunderstand. What I'm after is how the oil pump intermediate shaft should be installed in the motor based on a fresh engine rebuild. I should not have to back into that based upon distributor positioning. Is this not documented somewhere
[Re: AtomicDog]
#965111
04/03/11 01:49 PM
04/03/11 01:49 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
if you are talking about the slot in the oil pump gear, I have always installed mine so that the slot was inline with intake manifold bolt number 1. If you are keeping it computer controlled, after you fire it up you will need to take it to someone like a dealership and have your fuel sync set. At least that is how it is with my 2000 not sure about the fuel sync on the 1996
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#965112
04/03/11 02:20 PM
04/03/11 02:20 PM
Posts: 859 VA
AtomicDog
VA
Yes, the orientation of the slot in the oil pump gear is exactly what I'm trying to ensure is correctly aligned, given that the motor is curently sitting at TDC on the firing stroke. I'm trying to avoid having to take the truck to the dealer after this motor is installed in the truck. I combed thru the factory service manual and it has no mention about the installation of the oil pump drive and the orientation of the slot. I know I have seen this in the service manual for earlier years of the small block and big block motors, so I'm suprised that I can't find this info for the 5.9 motor.
