Re: Holley Dominator Screen Kit???
[Re: BradH]
#965030
04/05/11 11:42 AM
04/05/11 11:42 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Your local stereo shop has these in all sizes. Stereo speaker covers,the local shop give me mine. Drill a hole in the middle bolt them,notice mine is setting on the edge of the injector(carb.)not where the scoop tray sits.That way it does not affect the scoop height.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: dragram440]
#965032
04/05/11 05:16 PM
04/05/11 05:16 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Here's what I did. Got a Quick fuel air bell 11 inch diameter, added a K&N Extreme top 9 inch diameter. Better filtering than just screen.Fit under a 3 inch tall hood scoop. Both available at Jegs.
This is a really good idea. I need a bigger scoop or a 4500 intake without the 2" adaptor. Does the 9" top seem to flow enough air through it? Do the carb vent tubes clear the bottom or did you have to cut them off a bit? Looks good Im going this route for sure!
The carb vents fit in between the filter ribs in the Xtreme top. I've only used the 9 in top. Bought it 1st, it worked and I saw no need to spend additional $$$ on 11 inch top...
[Re: actionange]
#965033
04/14/13 12:28 PM
04/14/13 12:28 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Bringing back a really old thread here, but I need a filter for the 950 HP and have an 11" K&N Extreme lid laying around, a Quick Fuel air bell is pretty cheap...Anyone else tried this? I've also read the Extreme tops result in a HP loss when used with a filter so I was curious. FYI: I have a functional forward facing hood scoop. Thanks
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#965034
04/14/13 01:01 PM
04/14/13 01:01 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
The extreme lids will lose power(8 HP at peak, twice on two different motors, two different engine dynos and carbs ) on a engine dyno test but they will make the car with close hood scoops run faster(.030 Et ,3 MPH) at the track when tested against a steel lid on the air cleaner. That test was done on a Duster with a 440 motor using Dominator and a six pak style scoop IHTHs
[Re: Cab_Burge]
#965035
04/14/13 01:05 PM
04/14/13 01:05 PM
Adobedude
New Mexico
The motor is offset to the passenger side in a Dakota so I either need to make an off set base or get a uni filter, it will still fit under the hood scoop even though it's off center.
That's why I was wondering about the QF bell housing and extreme lid
[Re: actionange]
#965036
04/14/13 01:44 PM
04/14/13 01:44 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Nice job on that Ange,wonder if it would be better if you sealed it to the scoop.K&N does not make an extream top small enough for my set up,I was thinking about a screen set up for race days.The only thing I came up with would be a pair of strainers
