'99 Chrysler Sebring Convertible top problems #962546
03/30/11 06:17 PM
03/30/11 06:17 PM
MN
JERICOGTX Offline OP
MN
Need some help. A coworker of mine just picked up a Sebring convertible, and the top does not go up. I checked, and it is getting power to the relay under the rear seat. I bypassed the pump, and it runs, just didn't try it ong enough to make the top go up. Dealer told him they do not make the relay's any more... Is it possible it could be something else I'm not thinking of? Checked all fuses, and no problems.
Jeff
Re: '99 Chrysler Sebring Convertible top problems [Re: JERICOGTX] #962547
03/30/11 07:01 PM
03/30/11 07:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried a parts store for the relay?
Re: '99 Chrysler Sebring Convertible top problems [Re: stumpy] #962548
03/30/11 10:17 PM
03/30/11 10:17 PM
NJ
rth Offline
rth  Offline
NJ
when you say bypass pump do you mean put power to it directly?if so even if it ran a bad one heats up fast and won't work under a load.check for 12v and ground at pump connector while operating switch.this will determine elect or hyd problem.my sebring had a bad pump.
Re: '99 Chrysler Sebring Convertible top problems [Re: rth] #962549
03/31/11 06:18 AM
03/31/11 06:18 AM
MN
MN
Yes I put power to it directly. No power to the pump with the key on, running the switch. I have power to the relay, no nothing works. And no I cannot find a aftermarket relay either.
Re: '99 Chrysler Sebring Convertible top problems [Re: JERICOGTX] #962550
03/31/11 07:43 AM
03/31/11 07:43 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
most are protected by a circuit breaker- it could be open-done!
