camshaft talk #962508
03/30/11 03:27 PM
03/30/11 03:27 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Im thinking of changing camshafts to cut Et. I have 3260/lbs w/driver. 4 link 4.88, 542ci 14/1 comp. indy-1 cnc match flowed. indy 440-3 intake. 1150 dominator, 2" headers 5000stall 727 w/trans bk. 16-31-15 tires. what have you got? If we have any Camshaft expertise on here. this could be a good post.
Re: camshaft talk [Re: robnbird] #962509
03/30/11 03:47 PM
03/30/11 03:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Im thinking of changing camshafts to cut Et. I have 3260/lbs w/driver. 4 link 4.88, 542ci 14/1 comp. indy-1 cnc match flowed. indy 440-3 intake. 1150 dominator, 2" headers 5000stall 727 w/trans bk. 16-31-15 tires. what do you think? If we have any Cam xperts. this could be a good post.
By cutting the ET are you saying you want to slow
it down ...why not put a smaller carb on
Re: camshaft talk [Re: robnbird] #962510
03/30/11 03:52 PM
03/30/11 03:52 PM
organ
maximum entropy Offline
organ
what cam is in it now?
Re: camshaft talk [Re: MR_P_BODY] #962511
03/30/11 03:54 PM
03/30/11 03:54 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
O no cut it down. or quicker. Lower ET. I have two roller cams now and one is a very little quicker so Im thinking with the right comb of lobes might cut some off of the ET. Capiche
Re: camshaft talk [Re: robnbird] #962512
03/30/11 04:54 PM
03/30/11 04:54 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
At that level your not going to find any e/t in a cam swap... were talking hundredth's of a change in E/T. As long as the current cam isnt way off in left field.
I had a similar engine, and there was no e/t lost or gained.
557" Indy Maxx block 4.5 stroke x 4.44 bore 15:1 cnc ported 440-1's from Modern cylinder, Jesel rockers, .780 lift roller 274-278 ish @50 on a 110 LSA cam..
Toilet Injection on alky.
Car ran 144 MPH in the 8th mile well into the 7's.
Changed a cam cause I thought, and was told more power on tap....
.800+ roller, more duration diff lobes, slightly diff lobe center.... zero change.
Fact is it takes a good bit of power to pick up car at this power level... 8 or 10 hp doesnt show up very well in e/t, no more than good weather conditions or a good or poorly prep'd track anyways.
I dont see another cam making 20-30 hp over the current one, unless it was just flat out in left field for the combo.
I dont think there is any voodoo or black magic in cam design or selection. get the cam in the ball park to what the engine needs and the power will be there.
Converter choice is about the only single change I have ever encountered that can make a substantial diff e/t wise.
But If I was going to try another cam I would call up someone like...
Dewayne Porter
Brian (OU812)
Jeff
Bob George etc.
So they can get it right the first time...
