T/A rear springs #961331
03/28/11 11:28 PM
03/28/11 11:28 PM
NJ
Jay1454 Offline OP
Jay1454  Offline OP
NJ
Hi,
Has anyone ever heard of a T/A 4 speed with differnet size leaf speings on the driver and passenger sides. I have a numbers matching car and noticed the other day that it has 6 leafs on the Driver side and 8 (6 full and two half) springs on the passenger side..
Re: T/A rear springs [Re: Jay1454] #961332
03/28/11 11:44 PM
03/28/11 11:44 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
It was most probably changed by some one wanting to drag race. My T/A is original 45K miles and has the same leafs on both side as did all the ones I documented before I restored it. One thing about Mopars, never say never!
Re: T/A rear springs [Re: Jay1454] #961333
03/29/11 12:00 AM
03/29/11 12:00 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Check the bottom leaf one each side for the part number & post them.
Re: T/A rear springs [Re: Alaskan_TA] #961334
03/29/11 09:41 AM
03/29/11 09:41 AM
NJ
Jay1454 Offline OP
Jay1454  Offline OP
NJ
Driver side 3690266, Passenger side 3690265
Thanks,
Re: T/A rear springs [Re: Jay1454] #961335
03/29/11 10:05 PM
03/29/11 10:05 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They have been swapped in then.
From memory the T/A & AAR springs are 3400048.
Re: T/A rear springs [Re: Alaskan_TA] #961336
03/29/11 10:10 PM
03/29/11 10:10 PM
NJ
Jay1454 Offline OP
Jay1454  Offline OP
NJ
thanks,
do you have any idea where I can get a set? also how would i know if the schakels are correct? or were they all the same?
Re: T/A rear springs [Re: Jay1454] #961337
03/29/11 10:21 PM
03/29/11 10:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can try a want ad in the e-body parts wanted section here. Keep an eye on Ebay also.
A few years ago Mercer Spring in NJ had OE replacements for the shackles, they may still have some? Flagg Suspension Parts number CD400.
The bushings even had the Chrysler pentastar but the part number font on them was smaller than 1970 examples, at least on the set I replaced.
Re: T/A rear springs [Re: Alaskan_TA] #961338
05/16/11 03:13 PM
05/16/11 03:13 PM
NJ
Jay1454 Offline OP
Jay1454  Offline OP
NJ
HI,
DO you know what the arch measurement was for the T/A? I found a set and the plate with the casting number is good but the rest is shot. They are down at mercer spring and they were going to try to re-arch them but cann't find the spec.
Jay
Re: T/A rear springs [Re: Jay1454] #961339
05/16/11 09:12 PM
05/16/11 09:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have never seen the specifications for them, sorry.
