front brake bleed #960982
03/28/11 04:40 PM
03/28/11 04:40 PM
phx, az.
J code Chargers Offline OP
phx, az.
I have recently replaced the front brake hoses on a 67 Coronet with 11" drum brakes. The new hoses did not come with new copper crush washers so I re-used the washers that were on the wheel cylinder/old hose. My problem is I cannot seem to get the brakes to bleed properly. I continually have a REAL soft pedal, so soft the car is not driveable. Do I need to go back and install new crush washers?
Re: front brake bleed [Re: J code Chargers] #960983
03/28/11 05:04 PM
03/28/11 05:04 PM
Northwest
Four40mopar Offline
Four40mopar  Offline
Northwest
Never reuse the copper crush washers even if they look OK. Replacing the crush washers would be a good first step.
Re: front brake bleed [Re: Four40mopar] #960984
03/28/11 05:27 PM
03/28/11 05:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
But that is not your problem. Either your brakes are not adjusted right or not bleed right.
