360 Rocker/Push rod Question
#957972
03/24/11 08:25 PM
03/24/11 08:25 PM
Posts: 119 Orangeville, Ontario, Canada
Red Express
Ok,
Bought a set of comp rockers that accept a ball/ball pushrod... 360sb
Not sure if my OEM push rods are the right length... but... here is the question..
I think my OEM push rods are 9/32 dia and the rocker install sheet says to use 5/16 dia...
Will that 1/32nd of an inch make any difference?
Like I said I don't if the length will work anyway.. just curious what you guys thought.
I should say this is a street car that might do to the track once a year... .490 lift hydraulic cam.
Thanks..
Darcy & Allan MacCoubrey
Worlds Fastest Lil Red Express Truck
10.48 @ 128 mph
[url] www.raceosca.com [/url].
Re: 360 Rocker/Push rod Question
[Re: Red Express]
#957974
03/25/11 12:15 AM
03/25/11 12:15 AM
RapidRobert
Yes the ball dia must match the cup dia (if that is what you are asking)
[Re: RapidRobert]
#957975
03/25/11 09:16 AM
03/25/11 09:16 AM
Red Express
Do the lifters have a cup that needs to be matched or will any push rod work in the lifter?
I pretty much thought the push rods would be short but didn't know for sure... I'll mount them this weekend and mock it up for length.
10.48 @ 128 mph
