KB Hemi Street Blocks
#957791
03/24/11 05:15 PM
03/24/11 05:15 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
How do the KB Street Hemi blocks (water) compare to the World blocks ...? Does anyone have any pictures of the street KB Blocks? Experiences using this block on the street? KB blocks look to have far higher rigidity [Not interested in Indy as they have different dimensions for pain rail etc.]
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: KB Hemi Street Blocks
[Re: Bigcube]
#957793
03/24/11 06:09 PM
03/24/11 06:09 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i have a kb water block never had any other block to compare but i will find out how this one works out kb said it was to 2000 hp
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#957794
03/24/11 06:34 PM
03/24/11 06:34 PM
Keith Black®
QLD Australia
thanks guys, any cooling issues..? any pictures of the valley/deck area..?
[Re: Keith Black®]
#957797
03/24/11 07:20 PM
03/24/11 07:20 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Jim, are those "tiny" holes in the deck for cylinder head cooling ...!!???
Upper corners are much bigger, the little ones in the deck between the cylinders are just weep holes. One of them is for rocker shaft oiling, not used in my case.
[Re: Bigcube]
#957798
03/24/11 07:31 PM
03/24/11 07:31 PM
Keith Black®
QLD Australia
ok thanks, the world block appears to have significant water jacket holes also in the top between cylinders, and oil drain backs in the deck surface lower corners. Is this likely to be on the Hemi block? do you know if the lifters bores can be pressure fed for lifter oiling?
KB looks like a very strong piece.
[Re: Keith Black®]
#957801
03/24/11 08:22 PM
03/24/11 08:22 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Darren I've built many HEMIs using both blocks. The KB is a very stout block that can handle just about anything. KB's street block is really a racing block with water. I have a 1500 HP KB with a blower running for several years now. No issues.
The World block is good too. I like the fact that you can get the world block with lifter oiling and bushed lifter bores. You have to pay extra to get a KB block gun drilled and he sends them out to have that done. It's not done in house.
Street cooling is about the same. On the dyno the BTU extraction between the blocks is within measurement error.
Your decision on INDY is a good one.
Things to consider with any aluminum block: * Cam bearings can move with aluminum expansion. Have your machinist pin the bearings. KB will do this for you if you ask. * If you want oil to the lifter bores consider my above comments. * Both blocks use the same sleeves so leaks like that are far gone. * KB will install 1/2" or even 9/16" head bolts if you want. * Run steel main caps. That's the way they both come but don't change that.
One final comment that shouldn't be overlooked. Ken at KB is THE BEST at customer support. He wants to get you what you want and he will stand behind his product. I bought a new KB block several years ago just after Ken added some new CNC equipment. The cut for the rear main was slightly off. Ken took it back and fixed it for no charge. He even paid for the shipping. Great guy!
[Re: Mopar_Rich]
#957803
03/24/11 08:49 PM
03/24/11 08:49 PM
Keith Black®
QLD Australia
Hey Darren Your question on lifter oiling?? You have my HEMI book right?
thanks Rich, Yes I do have your book (2 as it turned out!). The reason I am asking is that I already have a World Block which I can sell at the moment. My engine isn't together yet has only been used for mock up purposes in the body so the interchangability of certain parts is important, like bellhousing (Chry pattern), starter with 140th f/wheel, Hemi engine mounts, Stage V heads etc. The engine will have peak HP of ~1,500, although it won't regularly be put through that, I don't want something that will break and durability/strength is important. The KB looks much stronger from the pictures. I think I will get a KB Block, get it gun drilled for lifter bushes and oiling, the lifter-bore accuracy will be very important to me so I'll ask about their tolerances on this. Like the idea of 9/16 head studs as my application is blown (F2), provided my StageV Replacement heads are for 9/16 studs or can be modified for them (i.e. drilled without concern). I have a pan so the original rail dimension is important. Am running reverse flow Meziere waterpump so hope the block is also alright with this.
Any information, pictures, & experiences with KB water block appreciated including approximate $$ people have paid.
[Re: Keith Black®]
#957804
03/24/11 10:03 PM
03/24/11 10:03 PM
Keith Black®
QLD Australia
Also, can anyone confirm areas of dimensional or structural difference..? i.e. I understand they don't have provision for mech fuel pump (doesnt matter for me), and the LH engine mount bolt pattern us different, no cross bolt for front mains(?), billet steel mains look stronger..etc, ...just looking for things that may be different from a fitment perspective..
Q: If you had the choice between an aluminium Hemi World block or KB Hemi water block, and strength, durability and std fitment of heads/pan/bell/ etc was of importance... which way would you go?
[Re: Keith Black®]
#957805
03/25/11 08:39 AM
03/25/11 08:39 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
KB aluminum hemi block here. Been street driving and racing it for almost 5 years w/ no issues. No issues w/ heat either. I use a Griffin aluminum radiator (2 rows of 1.25" tubes), '03 Viper electric fan, and a Meziere electric pump that fits in a stock housing. Keeps it plenty cool in the hot and humid South Carolina summers.
[Re: Keith Black®]
#957806
03/25/11 04:24 PM
03/25/11 04:24 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
you have to run either ele. or belt drive fuel pump also no provision for a oil pick up tube so will have tp run lines external to the oil pump i have the conversion motor mounts they fit really nice stock pan rails
