Anyone run a N/A Predator Head engine #957773
03/24/11 04:12 PM
03/24/11 04:12 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Just inquiring about PREDATOR headed engines. What combo you guys running. Looking for results from naturally aspirated combo aroung 2800-3200 lbs race cars. Any info will be greatly appreciated.
Re: Anyone run a N/A Predator Head engine [Re: FIREGUY12] #957774
03/24/11 04:45 PM
03/24/11 04:45 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Steve Gillman does,believe he goes by gillman38 on the board and he's like me,doesn't get on here much....
Re: Anyone run a N/A Predator Head engine [Re: Gary Robbins] #957775
03/24/11 05:27 PM
03/24/11 05:27 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
2500# car (ex-pro stock) Predator 605" goes 4.90's/7.70's, makes 1100hp with 2 1050 Dominators
Re: Anyone run a N/A Predator Head engine [Re: 64dodge572] #957776
03/24/11 10:29 PM
03/24/11 10:29 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
1231 n/a HP.
Re: Anyone run a N/A Predator Head engine [Re: boatracer572] #957777
03/24/11 10:30 PM
03/24/11 10:30 PM
San Jose Ca.
San Jose Ca.
in this.
Re: Anyone run a N/A Predator Head engine [Re: boatracer572] #957778
03/24/11 10:45 PM
03/24/11 10:45 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
What cubic inch engine are you guys running. Im looking to run mid to low 8"s at around 3200lbs.One carb
Re: Anyone run a N/A Predator Head engine [Re: 64dodge572] #957779
03/24/11 10:47 PM
03/24/11 10:47 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Do you have a bigger / better picture of that car?
I would love to see it. You could email it to me if need be.
Re: Anyone run a N/A Predator Head engine [Re: boatracer572] #957780
03/25/11 11:52 AM
03/25/11 11:52 AM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
1231 n/a HP.
Daaaang
What's the specs on that baby and who was the builder, if you don't mind........
Re: Anyone run a N/A Predator Head engine [Re: BIG BEAR] #957781
03/26/11 12:39 AM
03/26/11 12:39 AM
San Jose Ca.
San Jose Ca.
I built it myself a bunch of years ago. It's a 572" the heads flow 530+ cfm. On the intake @ 1" . the cams a 55mm. 2-3,7-4 swap. And is bigger than 1.0 lift. Comp. Is 16to1.. This motor has been a very reliable piece .
