Re: BB water pump housing (pass vs driver)
[Re: ff6849]
#957621
03/24/11 10:14 AM
03/24/11 10:14 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I don't think any diff. it was just diff setup made due the location change of some stuff into engine bay.
The change allowed to fit the steering pump deeper into engine bay, then on smogger engines fit the air pump over this.
also not more belt iddler pulleys at Water pump being the steering pump works like the belt iddler
but talking about OUTLET SIDE ? I don't think any advantage or disadvantage
[Re: Mr.Yuck]
#957623
03/24/11 11:03 AM
03/24/11 11:03 AM
Posts: 15,487 Florida
scratchnfotraction
pass side outlet on trucks driver side outlet on cars thats the way I see most of them do they make an alum one with passide outlet? does it change the t-cover and timeing marks like on a eairly SB and later SB? I would use one on my truck if they did
[Re: mikemee1331]
#957629
03/24/11 03:43 PM
03/24/11 03:43 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
i believe 440sourse has both sides available
so do I in the "iron" form.
[Re: Mr.Yuck]
#957631
03/24/11 05:28 PM
03/24/11 05:28 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
you're probably right. i only saw it in passing cause i was fishin' for drivers side.
