Deep pan for a 518 #957507
03/24/11 12:28 AM
03/24/11 12:28 AM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I'm looking for an aluminum deep pan for the 518 before I swap it in, and cannot for the life of me find one that includes both a drain plug, and temperature sending bung. A bit of a noob question here.... Can a steel temperature bung be welded into an aluminum pan?
Re: Deep pan for a 518 [Re: MarkZ] #957508
03/24/11 01:10 AM
03/24/11 01:10 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You could drill and tap an aluminum pan for the temp sending unit. If your looking for different aftermarket trans pans already setup for a temp probe, search for aftermarket trans pans used on the newer trucks with the 47/48RE transmissions.
Something like the MagHytec pan $237.50 (much nicer than the PML pan for about $10 more.)
http://www.puredieselpower.com/catalog/mag-hytec-dodge-72747re48re-transmission-pan-p-232.html
That one above should be OK on a car, the double deep pans like the ATS (holds 5 additional quarts) may hang down too much?
Re: Deep pan for a 518 [Re: MarkZ] #957509
03/24/11 01:34 AM
03/24/11 01:34 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
You would be a rich man if you could weld steel to alum.
Yow deep a pan do you want ? stock for that trans or deeper ?
Re: Deep pan for a 518 [Re: JohnRR] #957510
03/24/11 04:36 PM
03/24/11 04:36 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I'm looking for a pan with at least 2 extra quarts worth of capacity. Anything more than that though and I think clearance will start to become an issue.
451Mopar: That is a nice pan, but wow is that pricey. It costs half of what I paid for the TC.
B&M has a nice one for 727/518 has a drain plug and includes the filter extension. Would it be difficult to tap the aluminum pan for a temp sender, and still have it seal?
Re: Deep pan for a 518 [Re: MarkZ] #957511
03/24/11 04:41 PM
03/24/11 04:41 PM
U.S.S.A.
U.S.S.A.
Mark I have the P5007740 MP pan , it's 3.9" deep , has a drain plug and temp bung , brandy new , never used it.
Re: Deep pan for a 518 [Re: JohnRR] #957512
03/25/11 12:27 AM
03/25/11 12:27 AM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
You have mail.
Re: Deep pan for a 518 [Re: MarkZ] #957513
03/25/11 01:41 AM
03/25/11 01:41 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I put a B&M pan on my 2004.5 CTD. It's about the same depth as the stock diesel pan, but has a drain plug. It was the cheapest one I could find and it doesn't leak. The reuseable gasket that comes on the new trucks is nice too!!
Floyd Lippencott IV
Re: Deep pan for a 518 [Re: JohnRR] #957514
03/25/11 01:52 AM
03/25/11 01:52 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
http://forums.evolutionm.net/welding-fabrication/402877-aluminum-welded-steel.html
I've also heard that electron beam welding can weld aluminum to steel. Sort of out of my price range on most projects.
Floyd Lippencott IV
