New Wiring harness for 70 Cornet, what is this plug for #957379
03/23/11 11:02 PM
03/23/11 11:02 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I'm trying to figure out what this plug is for. Its blue and appears to be coming off of one of the alternator field wires.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957380
03/23/11 11:03 PM
03/23/11 11:03 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
another pic:
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957381
03/23/11 11:04 PM
03/23/11 11:04 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
oh...and I got the harness from YearOne (M&H)
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957382
03/24/11 01:02 AM
03/24/11 01:02 AM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Is it blue or violet. If its the violet one your talking about it would go to the temperature sensor in the front of the motor it memory serves me correct.
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957383
03/24/11 01:39 AM
03/24/11 01:39 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'll assume this is a big blk harness,(440/6?), if so the lead, bright blue coming off one of the alternator leads is for the carb solenoid,
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: DAYCLONA] #957384
03/24/11 01:45 AM
03/24/11 01:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sort of , but that one is not long enough to go to the other side of the intake. did a 70 big block have an idle solenoid on a 4bbl ?
Pat , looks like a bullet connector , ohm it out , see if it goes to the regulator or one of the fields , it could be for the idle solenoid.
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: JohnRR] #957385
03/24/11 01:54 AM
03/24/11 01:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Or the vacuum advance retard unit..
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: 1_WILD_RT] #957386
03/24/11 01:56 AM
03/24/11 01:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did they have that on a 1970 ?
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: JohnRR] #957387
03/24/11 01:58 AM
03/24/11 01:58 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
California...
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: 1_WILD_RT] #957388
03/24/11 02:00 AM
03/24/11 02:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
California...
of course they did
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: JohnRR] #957389
03/24/11 02:02 AM
03/24/11 02:02 AM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
Hi Shanker what particular 70 Coronet you working on.I was thinking that dark blue bullet connector was for the key on activated power to the AC or Carb solenoid .Hows the heavilly optioned RT doing these days
The Vacuum retard connector I believe was flat similar to the alt field type connector.Ac or Idle solenoid seems more likely to the one you pictured
http://www.mymopar.com/66to71_wiring.htm
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: JohnRR] #957390
03/24/11 02:11 AM
03/24/11 02:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
California...
of course they did
As it turns out according to this TSB all 70 383 & 440's
http://www.hamtramck-historical.com/images/TSBs/1970/D70-8-10.jpg
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: 1_WILD_RT] #957391
03/24/11 09:13 AM
03/24/11 09:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you can wait until later I can check the harness in my charger. It's a Y/O piece as well.
Coming soon!!!!
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: WINGCARS_6970] #957392
03/24/11 09:32 AM
03/24/11 09:32 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I'm working on the green one. I just finished a top-end rebuild and I'm getting it to the point where everything works (even the A/C) and I could drive it everywhere while I work on the Orange R/T..
My long term plan is to resto the Orange R/T, then sell it to help fund the resto of the green one.
Back to the wiring harness. This Blue wire with the bullet plug is not present on my OEM harness that is not butchered or anything of the sorts.
I've also got the 1970 Charger/Coronet Service manual sitting on the fender of that truck and it does not list that wire either. I'm going to call M&H today.
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957393
03/24/11 12:37 PM
03/24/11 12:37 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I got a reply from M&H:
The blue wire with the rubber mold on female bullet terminal states that it is for the distributor solenoid. I believe it is actually referencing an idle stop solenoid located on the carburetor. This circuit is tied into the keyed ignition. Cars with the A and E bodies also used an idle stop solenoid when equipped with the 440 v8. However the wire to attach to the solenoid was not included with the engine harness. Chrysler made an extension harness to be used.
So I guess I'll just pull that wire out of the harness since my car is not equipped with the idle stop solenoid anymore.
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957394
03/24/11 01:33 PM
03/24/11 01:33 PM
TX , NJ , FL
W
W
TX , NJ , FL
Shanker glad to hear the old 70 RT is getting a make over.I still have a 70 Coronet.If you need anything.The only other RT loaded with options like your is Adams in the UK.And 1 I found in town .Do you have a link or homepage debuting the R/T s make over procedures
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: WINGCARS_6970] #957395
03/24/11 02:42 PM
03/24/11 02:42 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I've been posting a few pics on facebook....now that I've got it running again I plan on doing a ton of detail work to make it look as good as it possibly can.
http://www.facebook.com/album.php?aid=2037587&id=1602646640&l=7191320dd7
Re: New Wiring harness for 70 Cornet, what is this plug for [Re: shanker] #957396
03/25/11 12:40 AM
03/25/11 12:40 AM
TX , NJ , FL
W
W
TX , NJ , FL
Thanks for the update and the link
