New Wiring harness for 70 Cornet, what is this plug for
#957379
03/23/11 11:02 PM
03/23/11 11:02 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
I'm trying to figure out what this plug is for. Its blue and appears to be coming off of one of the alternator field wires.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
Re: New Wiring harness for 70 Cornet, what is this plug for
[Re: shanker]
#957382
03/24/11 01:02 AM
03/24/11 01:02 AM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
Is it blue or violet. If its the violet one your talking about it would go to the temperature sensor in the front of the motor it memory serves me correct.
Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
[Re: DAYCLONA]
#957384
03/24/11 01:45 AM
03/24/11 01:45 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I'll assume this is a big blk harness,(440/6?), if so the lead, bright blue coming off one of the alternator leads is for the carb solenoid,
Sort of , but that one is not long enough to go to the other side of the intake. did a 70 big block have an idle solenoid on a 4bbl ?
Pat , looks like a bullet connector , ohm it out , see if it goes to the regulator or one of the fields , it could be for the idle solenoid.
[Re: JohnRR]
#957385
03/24/11 01:54 AM
03/24/11 01:54 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Or the vacuum advance retard unit..
[Re: 1_WILD_RT]
#957388
03/24/11 02:00 AM
03/24/11 02:00 AM
JohnRR
U.S.S.A.
California...
of course they did
[Re: JohnRR]
#957389
03/24/11 02:02 AM
03/24/11 02:02 AM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
Hi Shanker what particular 70 Coronet you working on.I was thinking that dark blue bullet connector was for the key on activated power to the AC or Carb solenoid .Hows the heavilly optioned RT doing these days The Vacuum retard connector I believe was flat similar to the alt field type connector.Ac or Idle solenoid seems more likely to the one you pictured http://www.mymopar.com/66to71_wiring.htm
[Re: shanker]
#957394
03/24/11 01:33 PM
03/24/11 01:33 PM
WINGCARS_6970
TX , NJ , FL
Shanker glad to hear the old 70 RT is getting a make over.I still have a 70 Coronet.If you need anything.The only other RT loaded with options like your is Adams in the UK.And 1 I found in town .Do you have a link or homepage debuting the R/T s make over procedures
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
[Re: WINGCARS_6970]
#957395
03/24/11 02:42 PM
03/24/11 02:42 PM
shanker
Corpus Christi, TX
I've been posting a few pics on facebook....now that I've got it running again I plan on doing a ton of detail work to make it look as good as it possibly can.
http://www.facebook.com/album.php?aid=2037587&id=1602646640&l=7191320dd7
[Re: shanker]
#957396
03/25/11 12:40 AM
03/25/11 12:40 AM
WINGCARS_6970
TX , NJ , FL
Thanks for the update and the link
