B body drums on an A body #957179
03/23/11 07:31 PM
03/23/11 07:31 PM
new port richey, florida
3
3phortyduster Offline OP
a friend of mine is putting disc brakes on his 69 roadrunner, will the front drums (10") from a 69 B body fit on my 71 duster or are the spindles a different diameter.
Re: B body drums on an A body [Re: 3phortyduster] #957180
03/23/11 08:34 PM
03/23/11 08:34 PM
If no ans (on here) might check one of the online part houses (rockauto?) & see if both of those apps have the same part # for a front drum
Re: B body drums on an A body [Re: RapidRobert] #957181
03/23/11 09:07 PM
03/23/11 09:07 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
And that runner should have had 11 inch drums, which would be gigantic on an A body.
Re: B body drums on an A body [Re: 3phortyduster] #957182
03/23/11 09:20 PM
03/23/11 09:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I can't say or recommend you do it but the RR drums will not fit on your A body spindles , you would have to use the B body spindle which has a different upper and more than likely lower ball joint than your duster .
Re: B body drums on an A body [Re: JohnRR] #957183
03/24/11 02:57 AM
03/24/11 02:57 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If you treat it just like the popular A body disc swap, then yes it will fit.
In simple terms, you WILL need the upper control arm from a 73-76 DISC brake A body car because all B body cars use the larger upper ball joint. ALSO, the 73-76 A body cars with 10 inch front drums also used the larger upper ball joint and control arm.
If you use the appropriate upper control arm along with the B body knuckle, drum, brake hose and lower ball joints, everything will bolt up. I did this exact swap on a 76 Dart to gain the larger bolt pattern. I replaced the left hand thread lugs though.
