Re: When did door / crash bars start showing up in Mopars?
[Re: RodStRace]
#956824
03/23/11 12:42 PM
03/23/11 12:42 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
1970 Look at the inside of an E body.... Also search for "1970 door impact beams" the Mavericks and Camaros got 'em that year too.
[Re: challenger70]
#956825
03/23/11 02:27 PM
03/23/11 02:27 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
It must be different for B,E and A bodies then. My 70 B body doesn't have them. I always thought 1973, but that might not apply to E bodies. I did read a thread that said later A's had them and IIRC that didn't start until around '73? Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: bigsbigelow]
#956826
03/23/11 02:35 PM
03/23/11 02:35 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I believe the side impact safety standards were raised in 1972. Side impact beams were mandatory from that date forward. It wasn't a bolt out of the blue. Auto manufacturers knew it was coming. Some models had them earlier than others.
[Re: bigsbigelow]
#956827
03/23/11 03:56 PM
03/23/11 03:56 PM
Posts: 502 St Louis, Missouri
Runnin74
St Louis, Missouri
I believe b-bodies certainly had them by 74. I've never seen a true 74 b-body door without them. Having said that, I know that one should never say never! I do have a 73 door for my 74 Road Runner and it does not have the bar. By the way there is a noticeable difference in weight between the two. My 74 Road Runner was built in early Dec of 73. I do not know the date for the 73 door that I have (the one without the bar) so perhaps spank04 is right with mid 73???
[Re: jbc426]
#956834
03/25/11 12:35 PM
03/25/11 12:35 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Working on a 70 grand Coupe vert that has them, don't know build date. Pretty much all others E's I've seen/owned had them so maybe very early E's didn't. Never seen them in 71/2B's Have a 73 Charger built 8/72 does not have them Have a 73 Satellite built 1/73 that does have them. All my 74B's have them
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: GODSCOUNTRY340]
#956836
03/25/11 01:26 PM
03/25/11 01:26 PM
DPelletier
Sounds like I was right then, the answer to the question is: it depends! Dave
1974 'Cuda
