Fuel Return Line
#956529
03/22/11 07:06 PM
03/22/11 07:06 PM
Posts: 1,534 Florida
CHRGR69
71 Cuda 383. The return line runs from back to the sending unit.
Grandma always said I had "hands of gold"!
Re: Fuel Return Line
[Re: CHRGR69]
#956532
03/22/11 11:46 PM
03/22/11 11:46 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
My GTX has 3, 1 supply line, 1 return from the filter, and 1 vapor return from the valve cover breather. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: CHRGR69]
#956534
03/23/11 12:39 PM
03/23/11 12:39 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Filter? You referring to the vapor seperator?
Yes , but a 383 didn't normally have a vapor separator
[Re: CHRGR69]
#956538
03/24/11 05:26 PM
03/24/11 05:26 PM
JohnRR
It shouldn't matter if I throw in a VS, right? Can't hurt?
If you have 3 lines and the car had ECS then you need one if you want to use that line , otherwise cap it off ?
