Fuel Return Line #956529
03/22/11 07:06 PM
03/22/11 07:06 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
71 Cuda 383. The return line runs from back to the sending unit.
Grandma always said I had "hands of gold"!
Re: Fuel Return Line [Re: CHRGR69] #956530
03/22/11 09:46 PM
03/22/11 09:46 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
No return line on a 383 cuda...
Re: Fuel Return Line [Re: screamindriver] #956531
03/22/11 10:11 PM
03/22/11 10:11 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
It has 3 lines
Re: Fuel Return Line [Re: CHRGR69] #956532
03/22/11 11:46 PM
03/22/11 11:46 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
My GTX has 3, 1 supply line, 1 return from the filter, and 1 vapor return from the valve cover breather. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Fuel Return Line [Re: rattler] #956533
03/23/11 11:56 AM
03/23/11 11:56 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Filter? You referring to the vapor seperator?
Re: Fuel Return Line [Re: CHRGR69] #956534
03/23/11 12:39 PM
03/23/11 12:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes , but a 383 didn't normally have a vapor separator
Re: Fuel Return Line [Re: JohnRR] #956535
03/23/11 01:00 PM
03/23/11 01:00 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Could it be a California ECS car?
Re: Fuel Return Line [Re: GomangoCuda] #956536
03/23/11 02:06 PM
03/23/11 02:06 PM
JohnRR Offline
JohnRR  Offline
That was a thought I had while I was typing the above .
Re: Fuel Return Line [Re: JohnRR] #956537
03/24/11 05:22 PM
03/24/11 05:22 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
It shouldn't matter if I throw in a VS, right? Can't hurt?
Re: Fuel Return Line [Re: CHRGR69] #956538
03/24/11 05:26 PM
03/24/11 05:26 PM
JohnRR Offline
JohnRR  Offline
If you have 3 lines and the car had ECS then you need one if you want to use that line , otherwise cap it off ?
Re: Fuel Return Line [Re: JohnRR] #956539
03/24/11 08:27 PM
03/24/11 08:27 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
I say if there's a way to hook it up (useable return line) do so. Wix makes at least two, in 5/16 and 3/8, with 1/4" return fitting. All you have to do is be sure the 1/4 fitting is up with either the filter vertically or horizontally
Re: Fuel Return Line [Re: CHRGR69] #956540
03/24/11 08:44 PM
03/24/11 08:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Heck yes use it. You will need a new sending unit in the gas tank that has a return nipple in it and either a original style vapor separator mounted on the fuel pump(my prefence) or a after market like what was mentioned.
I have 2 cars setup this way and have driven them a LOT in extreme conditions and they have performed great. Used to have vapor lock before.
The third line connects to the breather on the engine valve cover and is the vent for the gas tank.
Re: Fuel Return Line [Re: CHRGR69] #956541
03/24/11 09:17 PM
03/24/11 09:17 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sounds like someone equipped the car with 440/6 or hemi fuel lines and the car had ECS, which exactly what I did with the original 318 ECS car I showed above, say good by to vapor lock.
Re: Fuel Return Line [Re: Yancy Derringer] #956542
03/25/11 11:43 AM
03/25/11 11:43 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Would this work? http://cgi.ebay.com/ebaymotors/FRAM-G349...=item20b7f22f8b
Re: Fuel Return Line [Re: CHRGR69] #956543
03/25/11 01:25 PM
03/25/11 01:25 PM
Montana
Y
Y
Montana
That's one, but I do not like Fram filters
33040 Wix or 3340 NAPA is 5/16 fuel, 1/4" return
33041 Wix or 3341 NAPA is 3/8 fuel, 1/4" return
http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33041
Re: Fuel Return Line [Re: Yancy Derringer] #956544
03/25/11 01:37 PM
03/25/11 01:37 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Perfect! Ordered from Summit! Thanks
Re: Fuel Return Line [Re: CHRGR69] #956545
03/25/11 01:55 PM
03/25/11 01:55 PM
Cincinnati, Ohio
Cincinnati, Ohio
Why would you order one from Summit and pay shipping when every auto part store on the block will have one?
Re: Fuel Return Line [Re: Challenger 1] #956546
03/25/11 02:10 PM
03/25/11 02:10 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Hey Einstein, if its ok with you, I had to order other items anyway.
