High Vol. Oil Pump question #956190
03/22/11 12:07 AM
03/22/11 12:07 AM
USA
JoesMopar Offline OP
USA
Is a hardened shaft needed when using a HV Pump? Or can you use the stock one?
Re: High Vol. Oil Pump question [Re: JoesMopar] #956191
03/22/11 12:13 AM
03/22/11 12:13 AM
IN
ahy Offline
ahy  Offline
IN
The HV pump puts more load on the shaft - a hardened tip shaft with staked gear is recommended. I used one from MP (Mancini). The standard shaft can break with instant loss in OP.
Re: High Vol. Oil Pump question [Re: ahy] #956192
03/22/11 12:14 AM
03/22/11 12:14 AM
USA
USA
Thanks for the info
Re: High Vol. Oil Pump question [Re: ahy] #956193
03/22/11 01:08 AM
03/22/11 01:08 AM
. May I ask why are you going w a hi vol?
