Help! 78 New Yorker Fuse box issues #955267
03/21/11 01:23 PM
03/21/11 01:23 PM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
Hey guys, last night i was pulling my car into the garage when i notice my radio didnt come on when i started the car. So i go to the fuse box and it sparked and i lost all my Interior lights,tail lights,brake lights, head lights, etc. But the Turn signals work and so does the key buzzer and the clock. Im stumped and i need to use my car tomorrow for an interview. Please help.
Re: Help! 78 New Yorker Fuse box issues [Re: 71Polara383] #955268
03/21/11 02:40 PM
03/21/11 02:40 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Did the fuse panel spark when you touched it ??? Time to replace the opened (burnt) fuses . . . also, check to make sure you don't have any contact to ground . . .
Mark
Re: Help! 78 New Yorker Fuse box issues [Re: a12rag] #955269
03/21/11 02:57 PM
03/21/11 02:57 PM
Rockford,IL
Rockford,IL
No burnt fuses, but the car starts. I dont have any inside lights or parking lights/tail and head lamps, no brake lights. Fuse box sparked and out went the lights. again No burnt fuses. This is really getting on my nerves. I need this car to get back and fourth to work.
Re: Help! 78 New Yorker Fuse box issues [Re: 71Polara383] #955270
03/21/11 05:13 PM
03/21/11 05:13 PM
No burnt fuses, but the car starts. I dont have any parking lights/tail and head lamps, no brake lights. Fuse box sparked and out went the lights. again No burnt fuses.
Park/tail/head lites are powered out from the headlight sw. You have turn signals so from the kick panel rearward the TS/brake lights are OK as they are the same filaments. I'd pull a batt cable & dig into the fuse block & find the open/dead short/loose connection
Re: Help! 78 New Yorker Fuse box issues [Re: RapidRobert] #955271
03/21/11 05:16 PM
03/21/11 05:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Like Robert said pull the fuse box and check the wiring on the back side also.
Re: Help! 78 New Yorker Fuse box issues [Re: 71Polara383] #955272
03/21/11 05:17 PM
03/21/11 05:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Where exactly did it spark?
Which fuses are blown?
It sounds like you have a wire shorting out somewhere. Brake lights and headlights should be in separate circuits. If both of those fuses are blowing then you need to chase the wiring after the box.
Check the box to find out which side of the fuse has power coming in and which side goes out to the lights. Once you do that, check for a direct short to ground between the fuse connection going out and a chassis ground. If you have a short look for bare or damaged wires. You can move the harness around to see if the short goes away as the wires move.
A bad turn signal switch could cause the problem too. The brake lights and front side markers are joined at the turn signal switch. If it shorts out it can blow both fuses. The headlights are on the same fuse as the side markers.
I don't think the lights will work if the switch is unplugged. You can unplug the flasher and see if the brake lights still work after replacing the fuse.
- Stu Harmon
Re: Help! 78 New Yorker Fuse box issues [Re: stumpy] #955273
03/21/11 05:20 PM
03/21/11 05:20 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
I had similar circumstances with the 69 Coronet. Two steps have been taken since then:
1. Put a battery disconnect switch on in case of the worst
2. I stay out of the area behind the fuse box because I do not have the skill/info to go there. I get competent help from another Moparter on-scene.
Be careful.
Re: Help! 78 New Yorker Fuse box issues [Re: DennisH ] #955274
03/21/11 05:54 PM
03/21/11 05:54 PM
Andrewh Online content
Andrewh  Online Content
I could only look at a wiring diagram for a 76. hoping it is simlar.
both of those circuits show a fusable link.
also you have some weird relay for power under the hood as well it seems.
but check first under the hood for burned fusable link. I don't think headlights have any other fuse.
Re: Help! 78 New Yorker Fuse box issues [Re: Andrewh] #955275
03/21/11 08:52 PM
03/21/11 08:52 PM
Rockford,IL
Rockford,IL
Thanks for you input guys. I busted out the Haynes manual and looked at the wiring diagram and like andrew said a fusible link powers the head light switch and fuse block, the diagram said to follow the alternator wire back behind the engine, spark spark, Theres the problem, burnt fusible link. Disconnected the battery, Spliced a fusible link from the Dobas old harness and Shizzam! Im back in Business! Thanks again for your imput guys! I'm 18 so im still learning, and wiring isnt my hottest subject but i'd say i knocked this one out really easy. And to think i was about to take it to the shop.
Re: Help! 78 New Yorker Fuse box issues [Re: 71Polara383] #955276
03/21/11 10:49 PM
03/21/11 10:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You fixed the problem but you did not fix the cause. It has a 100 percent chance of burning that link up or worse if you did not use the correct fuse link.
Re: Help! 78 New Yorker Fuse box issues [Re: NITROUSN] #955277
03/22/11 11:46 AM
03/22/11 11:46 AM
Rockford,IL
Rockford,IL
the cause was a broken flasher arcing on the dash. Or a the horn relay was grounding on the dash because the fuse box was loose under the dash.
