Re: 440 6 Pack Air Cleaner. Where did it come from?
[Re: 4406CudaMike]
#955107
03/21/11 04:03 PM
03/21/11 04:03 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
Welcome to MOPARTS & thanks for serving!! If steel - the air cleaner was used by the factory on '70-'72 440 3x2bbl cars. The engine could be from just about anything, 1st start by getting the numbers off the top pad on front of the block.
[Re: 6bblgt]
#955111
03/21/11 04:26 PM
03/21/11 04:26 PM
Posts: 5,660 Flint, MI
Gusteve
I Love the Unicorn Song!!
Flint, MI
Here's chart to get you started on decoding the #'s you find on that top pad.
http://www.yearone.com/updatedsinglepage...ngnumbers3.html
[Re: 4406CudaMike]
#955112
03/21/11 05:40 PM
03/21/11 05:40 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
Thanks man. I'll ask the old man to check it out once it is out of the shop. I asked the previous owner but he said he looked on the side and there were no numbers.
What years are better then others?
Depends on what you mean by better , what part ? The block , the entire engine itself ??? Blocks are basically all the same , HP doesn't make a difference when it comes to blocks , just some of theparts that were used , depending on the year , HP vs NON HP .
As said , Thanks for your service .....
