fixing leaking freeze plug #955066
03/21/11 09:30 AM
03/21/11 09:30 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
On my 2000 Dakota, Im a few drops will hit the garage floor, coming from the back part of the motor. I can't find where, so Im assuming the rear plugs between the block and trans.
Are there any good products out there to help stop this leak? Im not going to put pepper or an egg in..
Re: fixing leaking freeze plug [Re: TheOtherDodge] #955067
03/21/11 09:54 AM
03/21/11 09:54 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Make sure to rule out the rear intake bolts. Seen a couple break causing small leak. (magnum eng only)
Re: fixing leaking freeze plug [Re: buildanother] #955068
03/21/11 10:07 AM
03/21/11 10:07 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have had a couple rust out over the years, and one was between the engine and trans. If it is a freeze plug, and its rusted out, keep a good eye onit as it may all of a sudden let out a lot more....
Re: fixing leaking freeze plug [Re: Dragula] #955069
03/21/11 10:53 AM
03/21/11 10:53 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I have seen heater hose leaks at the fire wall hose clamp appear to be from the back of the motor,might check it out,if you haven't already.
Re: fixing leaking freeze plug [Re: pushbutton] #955070
03/21/11 07:54 PM
03/21/11 07:54 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Check it out carefully to be sure where it is leaking from. If it is a leaking core plug, and the truck is your daily driver, you may as well go ahead and yank the engine now and replace all of them. If you try and go with Stop Leak or something, it will probably be a temporary fix. And the plug will still blow a hole in it, but when it is 95* and your a/c is ripping you'll be on the side of the road. May as well do it now before the weather gets too hot.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: fixing leaking freeze plug [Re: GO_Fish] #955071
03/22/11 09:40 AM
03/22/11 09:40 AM
Houston, Texas
Houston, Texas
Thanks...I know it is not a leaky bolt (was kinda hoping it was) because I replaced the intake gasket a few weeks ago (leaking oil out the back) and that didn't solve it.
Checked the heater hoses last night and it wasn't that either...
Re: fixing leaking freeze plug [Re: TheOtherDodge] #955072
03/22/11 02:29 PM
03/22/11 02:29 PM
PA
70Duster Offline
70Duster  Offline
PA
If you are going to use a sealer, use Bars Leak Gold. This is a powder sold in a small tube (ground ginger root) available at WalMart for less than $2.00 per tube. This is exactly the same formulation as the GM Coolant Supplement Tablets that are sold and specified by GM to be added to the early Northstar engines (among other aluminum GM engines) with every coolant change. It will not clog heater cores.
Re: fixing leaking freeze plug [Re: 70Duster] #955073
03/22/11 10:09 PM
03/22/11 10:09 PM
Houston, Texas
Houston, Texas
Thanks! I will look into that.
Re: fixing leaking freeze plug [Re: TheOtherDodge] #955074
03/23/11 12:04 AM
03/23/11 12:04 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
you might look to see if it's the heater core leaking. a small leak would drip from the drain tube. clear the floor and lay some paper or cardboard down, and check for a leak after it sits for a few hours. might be easier to pinpoint the exact spot the drip is coming from.
Re: fixing leaking freeze plug [Re: TheOtherDodge] #955075
03/23/11 12:06 AM
03/23/11 12:06 AM
Missouri
galen Offline
galen  Offline
Missouri
Sealer will work temporary. I ended up replacing every plug. Your going to find a bunch of crud laying in the block behind the plugs. The back were the first to go on mine.
Re: fixing leaking freeze plug [Re: galen] #955076
03/23/11 12:11 AM
03/23/11 12:11 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
effen it is the FP's ... you are better off changing them in your driveway or garage than having them realy FAIL out on the track or 100 miles away.
Re: fixing leaking freeze plug [Re: dOc !] #955077
03/25/11 01:05 AM
03/25/11 01:05 AM
Central TX
roe Offline
roe  Offline
Central TX
Like guys here have said, "If one is going, they're all going". When one of mine went, I replaced just that one. Then when I got around to checking the rest, there were 5 other ones that were leaking and I didnt notice, or were so paper thin that just scraping it with a screwdriver put a whole in it.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: fixing leaking freeze plug [Re: roe] #955078
03/25/11 02:10 PM
03/25/11 02:10 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
You can delay the inevitable but I would plan on replacing them all as soon as you can.
Kevin
Re: fixing leaking freeze plug [Re: C-Tech] #955079
03/25/11 02:16 PM
03/25/11 02:16 PM
the house on the left.
cogen80 Offline
cogen80  Offline
on a small block it always seems to be the two in the rear drivers side of the block. one by the starter and the other in the same corner between the engine and trans. seems thats where all the sludge seems to gather and it rusts out those two freeze plugs.
