#954880 - 03/20/11 07:25 PM how much power will it make?
Spaceman Spiff Offline
Loc: jersey
anyone think this combo will make at least 375hp?
Stock bore 413, stock 916 heads, 9.5 compression, performer rpm, 750 holley and these cam specs.
Basic Operating RPM Range 2,000-5,800
Intake Duration at 050 inch Lift 227
Exhaust Duration at 050 inch Lift 241
Duration at 050 inch Lift 227 int./241 exh.
Advertised Intake Duration 279
Advertised Exhaust Duration 296
Advertised Duration 279 int./296 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.486 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.473 in.
Valve Lift with Factory Rocker Arm Ratio 0.486 int./0.473 exh.
Lobe Separation (degrees) 107
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
#954881 - 03/20/11 08:16 PM Re: how much power will it make? [Re: Spaceman Spiff]
RapidRobert Online   content
Loc: Lincoln Nebraska
Did you say 906 or 516 for the heads? What ex? Measured 9.5CR? I'd have to vote no
25,743 Registered Members
193,023 Topics
Who sells A-Body Rear Leaf Spring Rebuild Kits?
by vinnyd76
Today at 09:58 AM
Rich Edelebrocks
by moparjack44
Today at 09:37 AM
Converting a 12 volt battery to 16 volt
by Sammy
Today at 08:50 AM
What brand Ring & Pinion are you running in your 8.75 rear?
by vinnyd76
Today at 08:49 AM
