Page 1 of 3 1 2 3
Coan super sprag for street, strengths/drawbacks? #954619
03/20/11 05:08 PM
03/20/11 05:08 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
69 Satelite,528 hemi. This is mainly a street car and still uses a modified vb that retains auto function. Short story, went to a regional outlaw track for a fun run/race. Poor track prep, hooked hard on drag radials, got out about 30 ft and the tires broke loose/hooked up again and busted my sprag. In thirty years of street driving and bracket racing, this is the first time that I broke a trans and don't want to repeat it. Would upgrading to the Coan super sprag be a worthwhile investment? Are they just harder to break, or virtually unbrakeable? Do you have to do any other mods to use one? I looked on their site and read the instructions and it is basically a bolt in, I have a good torqueflite guy who builds my transmissions. I really dont know much about automatics, so any advice is welcome! Thanks, Lee.
Re: Coan super sprag for street, strengths/drawbacks? [Re: Lee446] #954620
03/20/11 05:18 PM
03/20/11 05:18 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What exactly broke? I don't see any drawback to the super srag other than the cost. It has more rollers , they are a bit smaller in diameter , but the added amount of rollers makes it virtually impossible for the rollers to lay over which in turn allows the front drum or overspeed and EXPLODE should it reach that critical mass RPM. But making it so the rollers can not rollover will find the next potential weakness ... THE CASE .... but the Super sprag is a bolt in and I assume it's a 6 bolt like the A+A spag I just installed in a street trans I'm building. If so make sure you add the extra bolts if your trans has a 4 bolt rear support, it will require drilling holes in the case and potentially doing a little machining to the case. I spot faced where the new bolts sit and I think on a 1970 case I did I had to do some minor machining of a boss that was in the way, I counterbored it.
Short of it ... DO IT , you may or may not want to think about putting in a billet drum , the Super sprag will be extra insurance if you get a billet front drum.
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954621
03/20/11 09:15 PM
03/20/11 09:15 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Don't know yet what all broke, I took it to my trans guy friday afternoon. He says that they frequently break the case internally when the sprag goes, but I saw nothing on the outside. I don't mind spending the money for the added safety factor, just wanted to make sure what else I might need to get to do the job. Any suggestions for other improvements ? Thanks!
Re: Coan super sprag for street, strengths/drawbacks? [Re: Lee446] #954622
03/20/11 10:16 PM
03/20/11 10:16 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
OTHER than a low band apply manual VB ... there is NO WAY to get-away from the possibility of "busting" a sprag. I think that the aftermarket sprags are just another way dip-DEEP into your wallet.
I would just INSIST on better track-prep ....
..then have an uNdestructible front drum IN THERE ... like the steel one ..or the steel jacketed alum one.
Re: Coan super sprag for street, strengths/drawbacks? [Re: dOc …] #954623
03/20/11 10:30 PM
03/20/11 10:30 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well I can tell you that the Coan super sprag is using the sprag out of a ford c-6 trans and in 25 years in the business I have never seen a c-6 roll a sprag like the stock 727 do and that is because like stated above there are more rollers and there is just not enough room to roll them.
They are the only bolt in sprag that does anything for you other than save a bad case.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Coan super sprag for street, strengths/drawbacks? [Re: dusturbd340W5] #954624
03/20/11 10:37 PM
03/20/11 10:37 PM
Florida STAYcation
Florida STAYcation
.... so the Coan sprag for a TF is an exact C-6 piece ?
Re: Coan super sprag for street, strengths/drawbacks? [Re: dusturbd340W5] #954625
03/21/11 01:09 AM
03/21/11 01:09 AM
JohnRR Offline
JohnRR  Offline
The A+A sprag is different than the COAN but has more rollers also , I'm not familiar with the Coan but I can't see the A+A rolling over either .
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954626
03/21/11 07:17 AM
03/21/11 07:17 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
They both are 16 element.
Re: Coan super sprag for street, strengths/drawbacks? [Re: Leigh] #954627
03/21/11 10:26 AM
03/21/11 10:26 AM
JohnRR Offline
JohnRR  Offline
I thought one had more than the other , if not then there isn't much difference then ... I guess ?
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954628
03/21/11 06:19 PM
03/21/11 06:19 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
c6 sprag
Re: Coan super sprag for street, strengths/drawbacks? [Re: dOc …] #954629
03/21/11 07:35 PM
03/21/11 07:35 PM
Kissimmee Fl.
Kissimmee Fl.
Yes a Coan sprag come with a new inner and outer race that uses a C-6 sprag assembly.
Re: Coan super sprag for street, strengths/drawbacks? [Re: dusturbd340W5] #954630
03/21/11 11:23 PM
03/21/11 11:23 PM
JohnRR Offline
JohnRR  Offline
I think what the protologist is asking is if the entire assembly is a C6 piece and from your answer it is NO .
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954631
03/22/11 09:20 PM
03/22/11 09:20 PM
Kissimmee Fl.
Kissimmee Fl.
correct only the spring and roller is a c6 inner and outer races are not.
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954632
03/22/11 11:46 PM
03/22/11 11:46 PM
Florida STAYcation
Florida STAYcation
protologist
U R a piece of wurk RR ... you said you blocked me months ago .. but now you follow-me-around like a little puppy-dog SMELLING around the "protologist" area ....
FIND another hobby RR ... you are BUSTED ...
.... and BTW ....the correct spelling is PROCTOLOGIST..... NUMBnutz ..
Re: Coan super sprag for street, strengths/drawbacks? [Re: dOc …] #954633
03/23/11 09:46 AM
03/23/11 09:46 AM
JohnRR Offline
JohnRR  Offline
*** You are ignoring this user ***
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954634
03/23/11 10:57 AM
03/23/11 10:57 AM
Florida STAYcation
Florida STAYcation
Ahhhhhh ..... ... now go to yerr PROCTOLOGIST !
Yurrr head is stuck up-there so often that surgery in-that-area must be a weekly-thing ferr you ... and this FINGER must be a hourly occurance ...
Now where IS the flippinthebirdatRR smilie when I need-it ? ... !!
Re: Coan super sprag for street, strengths/drawbacks? [Re: Lee446] #954635
10/13/11 04:44 PM
10/13/11 04:44 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
some good info here.i am needing to fix my sprag so if there are any result or info i would like to hear it.
Thanks!
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954636
10/13/11 05:08 PM
10/13/11 05:08 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
The Coan sprag in my transmission is 4 bolt.
Everybody makes fun of a hillbilly until they need something fixed
Re: Coan super sprag for street, strengths/drawbacks? [Re: Clanton] #954637
10/13/11 05:10 PM
10/13/11 05:10 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Put in either the Coan or the A&A 16 element sprag. It will be just fine on the street. The only draw back is cost. We had a customer break a rear end with a 727 and a Coan Supersprag. The Sprag held, but was damaged. Most importantly it held and didn't overrun the drum.
Larry
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Coan super sprag for street, strengths/drawbacks? [Re: B_Body_Bob] #954638
10/13/11 05:13 PM
10/13/11 05:13 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
thanks i just checked that out at coan.my rollers ran over most of the springs in there going from what is in my pan.
Page 1 of 3 1 2 3
