64 polara motor mounts BB & power steering bracket #954294
03/20/11 06:54 AM
03/20/11 06:54 AM
strum, WI
demonbeekeepr Offline OP
strum, WI
I have a 318 push button car that has been changed to a 413 4 speed need info on the correct steel motor mounts with power steering and a power steering pump bracket. Need to purchase these items. I have the rubber mounts need the steel brackets. pictures ,info where to purchase on a budget so trying to do as cheap as possible 318 k frame and power steering still in car thanks rckustom@gmail.com Also need rear leaf springs was wondering what was interchangeable or best place to get new?
Re: 64 polara motor mounts BB & power steering bracket [Re: demonbeekeepr] #954295
03/20/11 07:22 AM
03/20/11 07:22 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A member here Joesixpack I believe has the mounts.Springs it depends.SS will work with the correct hangers.You could get yours rearched.My kid had his 62 300s done about 12 years ago.Better than new ones.I believe Mancini carries stock sprinfs also.BB mounts are the same PS or manual steering.Rocky
Chrysler Firepower
Re: 64 polara motor mounts BB & power steering bracket [Re: therocks] #954296
03/20/11 07:25 AM
03/20/11 07:25 AM
strum, WI
strum, WI
thanks for the info
