Best mech fuel pump 440-6
#953022
03/18/11 07:48 AM
03/18/11 07:48 AM
Posts: 123 Gold Coast, Australia.
6pacdave
Hi guys Going 6pak on my mild 440. Looking for a good mech pump. Do I need to have 8-9.5 psi or can I run a 6-8.5 Im looking at Carter pumps and was going for the dual diaphram 8-9.5psi but I see both pumps have 120gph
cheers Dave
70 GTX
70 Chevelle SS396
69 Mustang F'back
Re: Best mech fuel pump 440-6
[Re: 6pacdave]
#953023
03/18/11 07:52 AM
03/18/11 07:52 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We had some bad luck with 4 Carter pumps.Went back to Holley pumps.Mine feeds my 1050 Dominator with no problems.6 to 7 psi is more than enough for what you have.8 to 9 will probally blow the needle valve off the seat and flood.Rocky
Chrysler Firepower
[Re: 6pacdave]
#953024
03/18/11 07:59 AM
03/18/11 07:59 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I been running Carter street or strip mechanical pumps on my sm and BBblk 6 pak motors, for the last 25+ yrs, with never a failure, nice pumps,....if your running the stock rubber needle seats stay with the street pump, as the strip pump (8+ psi) will pressurize the needles when they close, and force them into the seats, preventing them from opening, resulting in no fuel DAMHIK ....if you want to run the strip pump, Holley has high volume/pressure steel or titanium seat assys,.....myself I generally run the strip pumps, and steel seats
[Re: DAYCLONA]
#953025
03/18/11 08:36 AM
03/18/11 08:36 AM
therocks
Niles , Ohio
We ran Carters also.Till I hade 4 bad ones.One was street strip SB and never pumped.One BB the arm broke and the spring went in the pan.Replaced it with my 25 year old Holley till we could get a new one.One lasted a week in my BB another only had 3 to 4 psi street strip BB.Put a Holley on and had 6 to 7 psi.Rocky
Chrysler Firepower
[Re: Mr.Yuck]
#953030
03/18/11 07:46 PM
03/18/11 07:46 PM
6pacdave
OK, cheers guys, I'll go for the smaller Carter andmight check the NAPA one too. I want the orig look, so prefer no chrome.
70 GTX
70 Chevelle SS396
69 Mustang F'back
