TCI rattle balancer hitting stock timing cover on 440 #952069
03/16/11 05:06 PM
03/16/11 05:06 PM
Vallejo, CA
ditchdrift Offline OP
Vallejo, CA
I'm building a 512 for a customer and i installed a tci rattle balancer that the customer provided, the bolts that hold the balancer together are hitting the stock timing cover where is slightly bulges outward. Has anyone had this problem? I'm thinking to just tell him to return this one and get a summit sfi one. I noticed that the summit one was slightly smaller in diameter vs. all the others. Any ideas? Am i missing a spacer?
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: ditchdrift] #952070
03/16/11 06:03 PM
03/16/11 06:03 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
If you left out the oilslinger by any chance that could put the balancer slightly nearer to the cover. But only the width of the oilslinger ofcourse.
Depending on how the belts will line up I would space it out a bit.
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: BigBlockMopar] #952071
03/16/11 06:31 PM
03/16/11 06:31 PM
Vallejo, CA
Vallejo, CA
the thing is that its not slightly but enough to gouge the cover and dent it in... i'm not aware of any spacer that was required. I'm thinking of using another balancer and checking belt alignment.
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: ditchdrift] #952072
03/18/11 02:57 PM
03/18/11 02:57 PM
Vallejo, CA
Vallejo, CA
bump, anyone else?
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: ditchdrift] #952073
03/18/11 03:47 PM
03/18/11 03:47 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Did you check with TCI to see what they say? Sounds like it's going on too far,Is there noticable wear on the crank and key? Stock timing cover?
good luck, john
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: jvcuda] #952074
03/18/11 04:42 PM
03/18/11 04:42 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: KillerBee] #952075
03/18/11 05:36 PM
03/18/11 05:36 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Mine fit great big and small. 383 with stock cover
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: jvcuda] #952076
03/19/11 10:20 PM
03/19/11 10:20 PM
Vallejo, CA
Vallejo, CA
good luck, john
brand new stroker crank, and yes, a stamped steel timing cover. the bolts on the back side of the balancer are gouging the bulged out section on the cover.
Re: TCI rattle balancer hitting stock timing cover on 440 [Re: ditchdrift] #952077
03/19/11 11:59 PM
03/19/11 11:59 PM
would a made up spacer installed b 4 the dampener let it seat wo interference
