Rear Brake Replacement? #952002
03/16/11 02:15 PM
03/16/11 02:15 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I have a 66 Barracuda that I need to do the rear brakes on. Where do you folks go for your rear brakes shoes, hardware, wheel cylinders, etc?
Re: Rear Brake Replacement? [Re: mopowers] #952003
03/16/11 03:39 PM
03/16/11 03:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Autozone.
Try rockauto.com too.
- Stu Harmon
Re: Rear Brake Replacement? [Re: mopowers] #952004
03/22/11 10:50 AM
03/22/11 10:50 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
So the rear brakes are 10" x 1 3/4". Did these come stock on a 66 Barracuda?
The reason I ask is is I hate going into an auto parts store and asking for parts for something this old. They usually don't have a clue.
Re: Rear Brake Replacement? [Re: mopowers] #952005
03/22/11 11:03 AM
03/22/11 11:03 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The parts stores usually have all that stuff. 10x1 3/4 is common A body size through mid seventies.
Re: Rear Brake Replacement? [Re: buildanother] #952006
03/22/11 11:09 AM
03/22/11 11:09 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the input guys! So if I tell him 66 barracuda, he'll be able to pull up the correct parts?
Do you folks know of a good source for sbp 10" drums?
Re: Rear Brake Replacement? [Re: mopowers] #952007
03/22/11 11:18 AM
03/22/11 11:18 AM
chicagoland,usa
chicagoland,usa
The drums are out there but hard to get. I once had to get a couple for a napa parts employee that could not find them. (that was 8 years ago, don't know how hard they are to find now)
Re: Rear Brake Replacement? [Re: buildanother] #952008
03/22/11 02:33 PM
03/22/11 02:33 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Well it looks like autozone has everything I need. Everything but drums!
I can't find them anywhere.
Does anyone know where I can get 10 x 1.75" sbp drums?
Re: Rear Brake Replacement? [Re: mopowers] #952009
03/22/11 08:07 PM
03/22/11 08:07 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
mopowers,
I got my 10" X 1 3/4" rear drums (small bolt pattern) from www.rockauto.com
They are a Wagner BD60123 part.
Dan
Re: Rear Brake Replacement? [Re: DartGTDan] #952010
03/23/11 10:27 AM
03/23/11 10:27 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the part number. Unfortunately, Rockauto.com no longer carries them
I'll do some searching to see if anyone else carries that part #.
