manual box input diameter #951399
03/15/11 06:19 PM
03/15/11 06:19 PM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
i have a manual steering box. the input shaft is 3/4 inches the power box on my 73 roadrunner is 5/8 inches. is this normal sizes? will an adapter for power to manual conversions work? i cant find the sizes at flaming river
Re: manual box input diameter [Re: 1340busa] #951400
03/15/11 09:33 PM
03/15/11 09:33 PM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
mine may be a 74 because the rag joint is near the firewall. with the flaming river coupler kit do you have to cut your steering shaft?
Re: manual box input diameter [Re: 1340busa] #951401
03/15/11 10:02 PM
03/15/11 10:02 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
manual car boxes are 3/4-36 spline, and the power ones are 5/8 diameter. There are adapters avl. to switch from power to manual from several sources. The (car) boxes themselves are pretty much interchangable, with exception of pitman arms in a lot of instances.
