5.7 Hemi cam recommendations
#951309
03/15/11 05:07 PM
03/15/11 05:07 PM
Posts: 2,158 God's Country - Etowah, TN.
A34
Hey guys, I'm looking for cam recommendations for my 5.7 Hemi. It's in a 04 Ram quad cab 1500 and I want to improve the towing. I have 3.92 gears. I have a cold air intake and will be adding headers, high flow cats and mufflers, but I'm looking to improve the towing capability, not hot rod it. I tow about 9,000 lbs in an enclosed trailer. Would appreciate any cam suggestions. Here are a couple I have found that look promising: Tri-Power Xtreme™ Hydraulic Roller Camshafts http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=609&sb=2COMP Cams Xtreme Fuel Injected Camshafts http://www.summitracing.com/parts/CCA-112-501-11/but, I'm open to suggestions. Thanks !!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: 5.7 Hemi cam recommendations
[Re: A34]
#951312
03/16/11 07:55 AM
03/16/11 07:55 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I agree, the current cam is probably pretty much the optimal one for torque and sub 5000 RPM HP.
what's your beef with it now? take off from a stop? steady state cruising? if it's the former, maybe look into a higher stall torque converter, to get the engine in the powerband sooner from a stop instead...the latter, when the TQ is locked up, shorter tires or more gear would help.
[Re: A34]
#951313
03/16/11 09:08 AM
03/16/11 09:08 AM
Posts: 2,826 NY usa
540challenger
NY usa
Hey guys,
Thanks !!
Maybe look for a progamable tuner that has a tow setting. Then you can switch from stock to the tow tune when you need to.
[Re: A34]
#951314
03/16/11 09:13 AM
03/16/11 09:13 AM
Posts: 3,842 Ohio
john55
Ohio
bigger truck? 9000 lbs is a lot of weight for a a half ton maybe a gear ratio change would help, I put 4.56 in mine and it helped, but, at 65 mph now I'm turning about 2400 rpm in OD
The Plymouth Win You Over Beat Goes On
[Re: GomangoCuda]
#951316
03/16/11 03:39 PM
03/16/11 03:39 PM
A34
I've done some upgrades to the truck, the weight is not an issue for the suspension. The problem is it pings and struggles to go over the mountains.
So, I'm looking for more power and torque, so it doesn't struggle so bad. This shouldn't be rocket science, but all I find on line is hot rod stuff. I'm surprised no one has wanted to improve the towing.
DEO VINDICE
[Re: A34]
#951317
03/16/11 04:12 PM
03/16/11 04:12 PM
patrick
Grand Haven, MI
downshift...
a little bigger cam might help with towing at speed, if you downshift so your cruise RPM is near the torque peak.
