Holley HP EFI suggestions - kinda long #950887
03/14/11 11:06 PM
03/14/11 11:06 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
I am looking to pull the trigger on a new HP-EFI kit.
HP EFI 4bbl Throttle Body Fuel Injection SystemPART #: 550-411.
Was going to go with FAST EZ-EFI but I don't think you can beat the Holley features for the money. This kit is like 1749 at summit, plus I need a pump..
Right now I have a stock 318, what fuel pump should I get for this engine and system?
Anyone running this system-how well does the self tune actually work compared to EZ-EFI or even the Holley avenger EFI??
Plaz
Re: Holley HP EFI suggestions - kinda long [Re: plazomat] #950888
03/14/11 11:26 PM
03/14/11 11:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
With Holleys previous track record with EFI I wouldn't touch anything they sell.... You'll likely tell me about some magazine article you read that raved about how well the system works..... To which I'll tell you advertisers pay big $$$ to get nice things said about their products & unfortunately magazines need $$ more than integrity....
FAST EFI sells efi.. They don't have Holleys advertising budget so if you see an article it probably is an honest review....
Re: Holley HP EFI suggestions - kinda long [Re: plazomat] #950889
03/15/11 12:54 AM
03/15/11 12:54 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Doesn't include the O2 or the map sensor, and you still need a laptop. True self tuning it aint! But the worst part is the injectors above the throttle plates. Fuel gets splashed back off the plates so you must use an air cleaner and compensate for the fuel.
I really would like to see your feedback after you install the system. Good or bad it's what this forum is all about.
Re: Holley HP EFI suggestions - kinda long [Re: Mopar_Rich] #950890
03/15/11 12:58 AM
03/15/11 12:58 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
TBI and real fuel injection are 2 different things. TBI is a better carb from the fuel metering viewpoint but it has all the other carb drawbacks. Port injected real EFI is the way to go if you're going to spend the money do it right.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Holley HP EFI suggestions - kinda long [Re: HemiRick] #950891
03/15/11 01:08 AM
03/15/11 01:08 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
BTW if you want to talk to someone who knows EFI check the post below my previous post & click on the link to Mopar Rich's website.....
Re: Holley HP EFI suggestions - kinda long [Re: HemiRick] #950892
03/15/11 01:13 AM
03/15/11 01:13 AM
plazomat Offline OP
plazomat  Offline OP
Would love to go with MPFI but can't find a manifold for the 318 and my budget..everyone I look at wants like 4-500 to modify my manifold.
Mopar Rich,
I am pretty sure it comes with an O2, what are the issues with the self tuning and the holley?
Re: Holley HP EFI suggestions - kinda long [Re: plazomat] #950893
03/15/11 01:22 AM
03/15/11 01:22 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Something I typed out years ago that explains my dislike for Holley EFI... I bought one back in the late 90's after reading a couple magazine articles about what a great system it was... I knew it wasn't the trickest but it had to be better than a carb... Anyway ...
I ran a Holley Pro jection DFI system, it ran great....Sometimes...It had no memory capabilities, so the only way to find a problem was to be watching the laptop when it screwed up...If it were a hard fault, no problem, but intermittent problems weren't so easy...The first time I fired it up it had a failed injector...replaced TB assy under warranty...Next a intermittent air charge sensor, it was quicker to just buy one, only $50.00, running pretty good, took a road trip to LA, lost a MAP sensor about 15 miles from home, luckily it made the other 600 or so miles...Running good again, drove it most of the summer, not as consistent as the carter carb but way cooler to be able to pop the hood & say "Yeah its Injected"... Another road trip, Sacramento, on the way there I start getting a surge, about 40 miles from home the surge starts feeling worse, I pull off the freeway & the car dies...Call AAA & tow it home...Lost a fuel pump, leaned out & cracked a manifold...As it turns out the exhaust wound up fighting me for three years after that till I got both the warpt flanges & the other manifold replaced as well...You know the carter runs really consistent I think FI is a good thing, I just feel Holley did a cheap half-a$$ job of it & used the cheapest components that the bean-counter in charge of purchasing could find...
Re: Holley HP EFI suggestions - kinda long [Re: plazomat] #950894
03/15/11 11:14 AM
03/15/11 11:14 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Mopar Rich,
hmm...switch to a magnum top end and use a stock magnum intake/tb?
a friend bought a holley 4di, could never get it to run right, ditched it, and bought a commander 950, a lot better, but 3 years later, still isn't totally tuned to perfection.
bummer with the FAST EZ-EFI in my book is the lack of ignition timing control.
2017 Grand Cherokee Overland
Re: Holley HP EFI suggestions - kinda long [Re: plazomat] #950895
03/15/11 11:46 AM
03/15/11 11:46 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Mopar Rich, I am pretty sure it comes with an O2, what are the issues with the self tuning and the holley?
I can't be specific because I personally haven't tried to use one. I can only go from what a few of my EZ customers have told me. The O2 comment comes from the Summit web site that lists what comes with the system. I've been in EFI for years and when I decided to start FAST Man EFI I went with a company where the software and hardware engineers are full time employees of the company because I knew I'd be pushing the envelope with custom configurations. I can call the FAST programmer and discuss issues one-to-one.
Manifold: You should be able to find a port injected manifold for your engine. Even from a junkyard. FYI: The EZ system is available for port injection. It's $825 minus the injectors and the TB.
Patrick - Ign Timing: Yes the EZ system does not control timing, but most people have a nice timing curve in what they already have, and that lowers the cost because no ignition stuff has to be bought.
Re: Holley HP EFI suggestions - kinda long [Re: Mopar_Rich] #950896
03/15/11 11:59 AM
03/15/11 11:59 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I am running the EZ system now and will be putting this on a few motors to test out in the next few months....( they dont do dual quads so it wont be going on my car.)
I'll give a report if your interested.
Re: Holley HP EFI suggestions - kinda long [Re: Mopar_Rich] #950897
03/15/11 03:09 PM
03/15/11 03:09 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Based on 'stock' and the avatar picture I'd guess the OP is running an LA318.
The port-FI options for small-blocks are (if memory serves):
Magnum - OEM beerbarrel
Magnum - Hughes Airgap ($600)
Magnum - MP single-plane intakes (2V style and spreadbore style)
LA 340/360 heads - Eddy Super Victor
(If anybody knows of ones I've overlooked please mention it.)
So I'd say there's no easy/cheap port-FI intake option here for a street/stock LA 318.
I'd also say that a TBI configuration is quite suitable for a stock 318. Millions of TBI GM cars/trucks for evidence...
Re: Holley HP EFI suggestions - kinda long [Re: Fury Fan] #950898
03/15/11 11:44 PM
03/15/11 11:44 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
A buudy of mime put a Holley fuel injection system on his SBC powered Jag. Keep in mind this guy is an honest to goodness genius. He designs, machines, and build electrical test equipment in his shop for a living.
He fooled around with that Holley system for several weeks and finally took it off and threw it away. He then took my inital advice and just put a big Holley carb on the car.
Re: Holley HP EFI suggestions - kinda long [Re: plazomat] #950899
03/16/11 09:33 PM
03/16/11 09:33 PM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
Mopar Rich,
I have a spare intake. It's an RPM Air-Gap I did for my first buildup. It's the one in my sig pics. It's currently on the shelf. The intake worked fine, the rails would need replaced as they were on the border of leaking. Feel free to contact me about it via PM. I'm even in the same country
Yes the price to modify these intakes is silly. Some company should produce the things! I think Mopar has an intake with suitable bosses over the runners, but it's for magnum heads. I think even Edelbrock has magnum head intakes with suitable bosses, how bad could it be to adapt to LA blocks? Ah well, the price of exclusivity.
Re: Holley HP EFI suggestions - kinda long [Re: Dartman75] #950900
03/17/11 12:46 PM
03/17/11 12:46 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Mopar Rich,
or just get some magnum heads
Re: Holley HP EFI suggestions - kinda long [Re: patrick] #950901
03/17/11 03:45 PM
03/17/11 03:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Because it's "just" that easy! Really probably would be worth it in this application tho if just for the cheap junkyard magnum intake.
Re: Holley HP EFI suggestions - kinda long [Re: DaytonaTurbo] #950902
03/17/11 04:03 PM
03/17/11 04:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The FAST EZ efi is worth the money. Love mine, the time slips show .01 better on 60ft and .3mph less on top end to a well tuned quick fuel with annular boosters..That's pretty close.
And with some of the digital timing systems available, that just a pay check away if you want it.
The other option is to find a Classic FAST system used and go with that. I have one I might sell just to upgrade to XFI on my one car. I see them for sale here and there.
Re: Holley HP EFI suggestions - kinda long [Re: DaytonaTurbo] #950903
03/17/11 05:14 PM
03/17/11 05:14 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
1) if looking for a cheap MPFI intake, it's your only option
2) big flow gains over 318 LA heads, with a nice compression boost
3)probably already has the lifters if he has an aftermarket (non MP) cam
4) only other changes needed would be new pushrods ~$50, and some modifications to his alternator bracket, probably.
Re: Holley HP EFI suggestions - kinda long [Re: patrick] #950904
03/17/11 09:08 PM
03/17/11 09:08 PM
Dartman75 Offline
Dartman75  Offline
A friend and board member did the magnum head swap. Kept his LA intake so had to drill the heads. But wow, that 318 with those heads would have slapped my bone stock 360 sideways so bad it would have been like I left the emergency brakes on. IfI had driven that 318 car before putting my 408 in the works, I'd have just gone that route I think. If you can do the head swap, that really will give a lot of both ponies and saves $$$ on intakes.
Re: Holley HP EFI suggestions - kinda long [Re: Dartman75] #950905
03/18/11 08:49 AM
03/18/11 08:49 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the old engine in my 5th ave was a stock pistoned 360 with a comp XE262, home ported 1.88 heads, headers, 600 eddie, and an RPM air gap, comp ratio was a tad under 8:1, ran hard on 87 octane, got 15mpg mixed
the new engine is the original 318 shortblock, magnum heads home ported by me, the same headers, intake and carb as the 360, a bullet 259/316 lobe hydraulic roller cam (10 degrees less .050 duration, 3 degrees less .2 duration than the comp XE262). comp ratio is 9:1, runs just as hard as the 360 on 87 octane, gets 17.5mpg combined.
Re: Holley HP EFI suggestions - kinda long [Re: patrick] #950906
03/18/11 10:25 PM
03/18/11 10:25 PM
plazomat Offline OP
plazomat  Offline OP
So not so much love for holley around here...looking into the warranty kinda sucks 90 days? on the other hand FAST is a year and voids it for race vehicles.
Head swap and mpfi are on the wishlist down the road but not possible right now. I figured holley tbi for now, later the MPFI harness for the same ECU is $100, keep the tbi air only and do swap.
I like the feature list of holley alot, but will have to look deeper into unbiased reviews to see if the quality is up to snuff.
Rich ever find out why you think the holley system isn't true self learning?
PLAZOMAT
