Re: When do you need adjustable rockers on a 383?
[Re: Stanton]
#950519
03/14/11 06:13 PM
03/14/11 06:13 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
12 inches isn't that low, chances are good if it's got a cam with much duration it's normal... Adding more base timing may help increase the vacuum & eliminate the bog.. there may be other issues that need looking at but I'd start with checking base timing.... Knowing cam specs would help...
[Re: Mike H]
#950522
03/15/11 01:25 AM
03/15/11 01:25 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi sounds like cam is retarded . degree it, prob needs 4deg advance ! ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Stanton]
#950523
03/15/11 08:56 AM
03/15/11 08:56 AM
Posts: 531 Virginia
RM21N0A
Virginia
Start your engine and open the valve on the torch (DON'T LIGHT IT). Move the torch nozzle around any areas that could potentially be a leak. If there is a leak you will notice an immediate increase in RPM.
![](/ubbthreads/images/graemlins/thumbs.gif)
Wow, amazing little trick.
I love this site. You never know when you are going to read something like this, that someone like myself would never even think of, no way, no how.
