Challenger Vinal Top install.....Easy ????? #95027
07/26/08 04:53 PM
07/26/08 04:53 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Can I do this myself without a helper ?? On the installs I have seen on TV or in magazines there is usally 2 or more people holding and others streching the vinal as it is pulled down on the roof. I have the wide seam 71 Challenger top. Do you install the back duchman panel area first or last ??? Thanks for any tips, tricks that you can share.
Re: Challenger Vinal Top install.....Easy ????? [Re: THESHAKERPROJECT] #95028
07/26/08 06:57 PM
07/26/08 06:57 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Here is a how-to from the tech archives.
http://www.moparts.org/Tech/Archive/misc/4.html
Re: Challenger Vinal Top install.....Easy ????? [Re: Neil] #95029
07/26/08 07:49 PM
07/26/08 07:49 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Tips, spend the $250 and take it to a professional, the glue alone we run $100-150 and as I understand it you have 1 chance to lay it just right. I will do most anything myself but not vinyl tops.
Careful, your character's showing!
Re: Challenger Vinal Top install.....Easy ????? [Re: THESHAKERPROJECT] #95030
07/26/08 10:17 PM
07/26/08 10:17 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
I just did a vinyl install on my charger. I was a first timer and by myself. I would suggest having one helper. I attempted it alone and because of that I have a new top on the way and have to do it again next weekend. With that said if I had a second set of hands it would have been really easy and would have came out perfect.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Challenger Vinal Top install.....Easy ????? [Re: 69charger440_6pa] #95031
07/27/08 10:20 AM
07/27/08 10:20 AM
WI
RestoRick Offline
RestoRick  Offline
WI
A Charger top is on the easy side... the Challenger wide seam is probably the most difficult top to do correctly... not saying it can't be done, but it will be difficult.
It has to be carefully centered and not overstretched when installed. The tricky/difficult part is getting the seam positioned properly relative to the drip rail.... the seam is a gentle sweeping curve that looks pretty ugly if it's pulled crooked.
Another area that can be challenging is below the rear window; if the material isn't stretched just right in the sail panel area and/or positioned just right, you'll end up with a pucker from too much material below the window.
Rick
Re: Challenger Vinal Top install.....Easy ????? [Re: RestoRick] #95032
07/27/08 04:56 PM
07/27/08 04:56 PM
NORTHERN VA
NORTHERN VA
Yeah Rick, That seam is what I was worried about...it dont look easy and the rear window area was also a concern. The problem is that there are not any shops around that do vinal tops anymore in this area.
Re: Challenger Vinal Top install.....Easy ????? [Re: THESHAKERPROJECT] #95033
07/27/08 07:31 PM
07/27/08 07:31 PM
WI
RestoRick Offline
RestoRick  Offline
WI
And I'm in WI... !!!
Re: Challenger Vinal Top install.....Easy ????? [Re: THESHAKERPROJECT] #95034
07/28/08 03:13 PM
07/28/08 03:13 PM
GMP440 Offline
GMP440  Offline
How much do you stretch the top when putting it on? It does not take much to get the seams distorted when putting it on.
Re: Challenger Vinal Top install.....Easy ????? [Re: GMP440] #95035
07/28/08 05:28 PM
07/28/08 05:28 PM
WI
RestoRick Offline
RestoRick  Offline
WI
You don't really stretch it except where needed...
in particular the sail panel on the Challenger.
The "normal" areas of the top are more of a "keep it taught" deal.
