Dual scoop template for 72 Duster or 72 Demon...I need #94836
07/26/08 01:02 PM
07/26/08 01:02 PM
Post Falls Idaho
GrizTrack Offline OP
Post Falls Idaho
I'm putting dual scoops on both a 72 Duster and Demon and would really like to find a template for doing this does anyone have a suggestion?
Thanks,
Brady
Re: Dual scoop template for 72 Duster or 72 Demon...I n [Re: GrizTrack] #94837
07/26/08 03:13 PM
07/26/08 03:13 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: Dual scoop template for 72 Duster or 72 Demon...I n [Re: AdamR] #94838
07/26/08 03:59 PM
07/26/08 03:59 PM
the house on the left.
cogen80 Offline
cogen80  Offline
latest mopar enthusiast magazine has an article on it. step by step with pics.
Re: Dual scoop template for 72 Duster or 72 Demon...I n [Re: cogen80] #94839
07/26/08 07:52 PM
07/26/08 07:52 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
i flipped them upside down and traced the scoops and bolt locations onto a clear piece of thin lexan.
then lay the lexan onto the hood where you want the scoops to go.
drill holes,install.
Re: Dual scoop template for 72 Duster or 72 Demon...I n [Re: west] #94840
07/27/08 04:02 PM
07/27/08 04:02 PM
cogen80 Offline
cogen80  Offline
what make is that glass hood??
Re: Dual scoop template for 72 Duster or 72 Demon...I n [Re: west] #94841
07/27/08 04:07 PM
07/27/08 04:07 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Way too easy. Take a piece of cardboard. Press the scoop down onto it to make stud impressions. Use the carboard as a template. Dimple the hood by centering inside the hood webbing that has been clearanced with holes (providing the stock location of the scoops). Then check the alignment of the template from the top side of the hood on the dimples you made, if it aligns drill those holes from below, then continue from the top using the template as your guide
