Re: Hard Starting??????
[Re: okie]
#946976
03/09/11 11:23 AM
03/09/11 11:23 AM
Posts: 5,270 Missouri
MY340
Missouri
Use mini-starters if you don't have them already especially with headers. Makes a world of difference plus today's gas does effect hot restarts too.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: okie]
#946977
03/09/11 12:01 PM
03/09/11 12:01 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I sounds like you are having issues with the fuel boiling/evaporating out of the carburator. An electric fuel pump, insulating the carb with a phenolic baseplate and rerouting your fuel line away from direct heat soak could help.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: DaytonaTurbo]
#946980
03/09/11 05:08 PM
03/09/11 05:08 PM
RapidRobert
next time b 4 you crank it take off the air cleaner & see if the AP still has fuel (squirts good) when you crack the throttle
[Re: jbc426]
#946981
03/09/11 05:41 PM
03/09/11 05:41 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I sounds like you are having issues with the fuel boiling/evaporating out of the carburetor. An electric fuel pump, insulating the carb with a phenolic base plate and rerouting your fuel line away from direct heat soak could help.
Same issue here. I am going to install a small electric pump to prime the system. Last summer I put about a half inch of gas in an old spray paint cap and left it on the bench next day it was gone, and I mean bone dry in less than 24 hours. It evaporated that quick.
[Re: okie]
#946983
03/09/11 07:47 PM
03/09/11 07:47 PM
RapidRobert
I just can't figure why the 383 was starting so good for it to stop doing it.
I missed that, it started acting up out of the clear blue sky w no changes on your part & (so far) no obvious cause? EDIT just thinking out loud, wondering if it is ign related & not fuel, check spark quality at a plug & reluctor gap/pickup continuity anything in that area
