Think the freshened up engine will make any more power? #946391
03/08/11 05:30 PM
03/08/11 05:30 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Looks like nobody wants to buy any of my parts currently for sale (yeah, the economy SUCKS all over), so I'll be putting the Challenger's 452 back together w/ the stuff I have on hand. Anyway, I'm bored... and curious about whether people think the work being done as part of the rebuild will have any change on how it runs.
Differences between "before" and "after":
Bottom end
- Cylinder bores re-honed
- Switching to file-fit moly rings from the old Total Seal Gapless top rings
Top end
- Same Stage VI heads, but the valves & seats got touched up
Lift -- Int / Exh
.100 --- 69 / 53
.200 -- 143 / 108
.300 -- 213 / 146
.400 -- 262 / 181
.500 -- 293 / 211
.550 -- 305 / 222
.600 -- 307 / 231
.650 -- 307 / 237
.700 -- 307 / 243
- Switching from 1.5 int & exh rockers to 1.6 intake / 1.5 exhaust combination
- Will either shim the old valve springs or replace them entirely (haven't decided, yet)
- Matched intake runners to head entries (match was basically OOB before)
Cam
- Old - COMP XX .874" flat-tappet solid used w/ 1.5 rockers int & exh
298 @ .20"
266 @ .050"
180 @ .200"
.400" lobe / .600" (1.5)
108 LSA + 2.5 (ICL measured at.020" lobe lift)
Ran w/ .024" lash hot
- New - Hughes 6468 flat-tappet solid
Duration at .050": 264 / 268
Lift: .633" (1.6) / .611" (1.5)
LSA: 108 + 3
Lash: .020" Hot
I guess the main questions are (a) whether the change in ring configuration & hone job will make any difference and (b) if the new cam & rocker ratio combination is worth anything vs. the original.
And I'm really hoping I can actually answer these questions sometime in the next 6-8 weeks.
Re: Think the freshened up engine will make any more power? [Re: BradH] #946392
03/08/11 05:33 PM
03/08/11 05:33 PM
organ
maximum entropy Offline
organ
huh uh.
Re: Think the freshened up engine will make any more power? [Re: maximum entropy] #946393
03/08/11 05:35 PM
03/08/11 05:35 PM
BradH Offline OP
BradH  Offline OP
huh uh.
Ummmm... is that grunt-eze for "Nope"?
Re: Think the freshened up engine will make any more power? [Re: BradH] #946394
03/08/11 05:35 PM
03/08/11 05:35 PM
UK
602heavy Offline
602heavy  Offline
UK
Look forward to the results.
Re: Think the freshened up engine will make any more power? [Re: BradH] #946395
03/08/11 06:12 PM
03/08/11 06:12 PM
NC
440Jim Offline
440Jim  Offline
NC
Those cams are very close. Did you check the 0.200" duration on the Hughes cam? Judging by the lobe lift (.395/.407), it should be within a couple degrees. My first guess is that the new cam is a tiny bit milder overall, but will idle worse. There is a chance it might handle the car's full exhaust system better than the straight pattern 108 Comp Cam.
If the car changes by more than 0.05 seconds (plus or minus) I will be surprised.
Re: Think the freshened up engine will make any more power? [Re: BradH] #946396
03/08/11 06:26 PM
03/08/11 06:26 PM
organ
organ
huh uh.
uh huh.
Re: Think the freshened up engine will make any more power? [Re: 440Jim] #946397
03/08/11 06:39 PM
03/08/11 06:39 PM
BradH Offline OP
BradH  Offline OP
I'll do a complete intake & exhaust lobe profiling during the assembly, but can't say how much different the cams are (other than on paper) at this point. I don't think they're much different, either, and the only "real" change will be from stepping up the intake rocker ratio.
I'd actually like it to run comparable to before so I don't have to question what I did wrong during the rebuild.
