Page 1 of 3 1 2 3
How much horsepower do you really need???? #94440
07/25/08 03:31 PM
07/25/08 03:31 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Ok just a hypothetical question here, how much horsepower do you really need for a relatively quick street car without sacrificing drivability/reliability or breaking the bank?
I just trying to plan and budget for a project car I’m contemplating. It’s a 71 Demon. My thoughts are a new generation Hemi (5.7 or 6.1, kind of why I asking this question) and an overdrive automatic trans, with probably a 3.73 to a 3.91 rear gear. This car will be a cruiser with much more street than strip time. Drivability means more to me than outright performance. I’m thinking that about 400 hp would really be all that I would need without getting too exotic or expensive. Also for any A body guys out there that are running similar specs, any idea how fast would this combo be in the quarter?
Any thoughts???????
By the way I already know that
A: Too much HP is never enough
B: Speed costs money son, how fast do you want to go?
Re: How much horsepower do you really need???? [Re: 70Sbird] #94441
07/25/08 03:40 PM
07/25/08 03:40 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
more power! grunt! grunt!
Re: How much horsepower do you really need???? [Re: 70Sbird] #94442
07/25/08 04:20 PM
07/25/08 04:20 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
i would build a stought 408 stroker bottom end and just use the stock heads for now. put an air gap on it with a descent holley. Then when the 400hp feels slow theres a lot more to be made
thats what i wished i had done.
Re: How much horsepower do you really need???? [Re: skep419] #94443
07/25/08 04:23 PM
07/25/08 04:23 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
My 340 was dyno'd at 370HP and 407 ft/lbs of torque, and that's more than enough for me. Especially with gas at $4.60.
Re: How much horsepower do you really need???? [Re: JF_Moparts] #94444
07/25/08 04:39 PM
07/25/08 04:39 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
I guess that I should add I'm almost completely settled on a new Hemi, with fuel injection, a/c, power steering and all of the "modern" convieniences.
I've just seen a growing amount of variability with offerings for this engine, from a junkyard 5.7L truck engine to an $18,000 6.1L beast from a nationally recognized engine builder.
Thanks for your input!
Scott
Re: How much horsepower do you really need???? [Re: 70Sbird] #94445
07/25/08 05:44 PM
07/25/08 05:44 PM
as much as you can afford or until it scares you whichever comes 1st.
Re: How much horsepower do you really need???? [Re: RapidRobert] #94446
07/25/08 05:53 PM
07/25/08 05:53 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
you didn't mention weight, suspension or tire size. If you figure around 3300, stock and the biggest tire is 27 tall, 8 wide, the 5.7 should spin them easily. with the deep rear gear and late trans, you should have gearing to pul smartly up to at least 90+. How much do you really need, and how are you planning on putting it down?
Re: How much horsepower do you really need???? [Re: 70Sbird] #94447
07/25/08 07:41 PM
07/25/08 07:41 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
This must be a trick question, right?
Re: How much horsepower do you really need???? [Re: 70Sbird] #94448
07/25/08 08:02 PM
07/25/08 08:02 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: How much horsepower do you really need???? [Re: forphorty] #94449
07/25/08 08:38 PM
07/25/08 08:38 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
A cam/headers 5.7 Hemi will do over 400 hp easily.
Pull a low mileage 5.7, sell the tranny, get a truck front dressing (accessories), get the TTI headers and the XV intake, put a cam and run that thing...really basic with LOADS of room to grow.
Go drive an LX car, and then imagine one with less drivetrain loss and 1000 lbs less weight. There are longblock cam and exhaust 5.7 cars knocking on high 12's @ 4000-4500 lbs...
We are putting a stock shortblock 6.1 into my friends 67 Charger with a carb based cam with worked 5.7 heads....it will fly, and we will detail the process to show how much power these motors will make on a budget.
https://board.moparts.org/ubbthreads/show...rue#Post4534456
Re: How much horsepower do you really need???? [Re: 70Sbird] #94450
07/25/08 09:51 PM
07/25/08 09:51 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I think any A-body + New Hemi is going to be a dynamite combo. I'm driving a 3600# Valiant with a low-squeeze 340 that makes an honest, untuned 300hp and 340lb-ft at the crank. With a 4-speed and 3.23 gears, it's a treat to drive - can spin the tires with ease, and has plenty of grunt. It's not the fastest car on the street at all, but it should crack in to the 13's. Add 100hp/lbft from the new Hemi and you're looking at 12's with virtually no down sides - except for initial cost, and complexity of fabbing up an injection system if you go that route.
IMHO, grunt makes the world go round. The HP will follow the torque if the breathing is there.
Clair
Re: How much horsepower do you really need???? [Re: 70Sbird] #94451
07/25/08 09:53 PM
07/25/08 09:53 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Always build more than you need. Remember, that's why we have throttles on these motors.
Re: How much horsepower do you really need???? [Re: 70Sbird] #94452
07/25/08 10:18 PM
07/25/08 10:18 PM
Depens on what you can live with regarding street manners in terms of idle and bucking at cruise speed. If you drive it regularly in heavy traffic you will want to take this into consideration.
Re: How much horsepower do you really need???? [Re: 70Sbird] #94453
07/25/08 11:01 PM
07/25/08 11:01 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
400 HP sounds like a good number, should put most cars in the 12's. If you go quicker than 11.50's the NHRA requires you to have a roll bar and other safter equipment.
Re: How much horsepower do you really need???? [Re: 451Mopar] #94454
07/25/08 11:42 PM
07/25/08 11:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It really depends on how fast of a street car you want ?? If you want to beat alot of these newer cars then you might want to shoot for 11's. I mean I saw a Mercedes at the track running 12.40's that I believe was the supercharged V8 deal. I figure my 63 makes about 500 hp at the flywheel to push it at 3700 lb's to mid 11's and it really is a very mild 440 by todays standards. But with an A-body the smallblock stroker is the ticket. Very easy to get 450 to 500 hp and that would put your A-body well into the 11's and still be very streetable as you can do it with 3.91's as that's what my son uses with the 400 in his Dart. Good luck , Ron
Re: How much horsepower do you really need???? [Re: 70Sbird] #94455
07/26/08 12:43 AM
07/26/08 12:43 AM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
I make 350hp and 400 ft lbs. from my 360 in my 71 Demon. With 3.23s its good for high 12's at about 105. Let me know if you want the engine combo
Re: How much horsepower do you really need???? [Re: DemonKyle] #94456
07/26/08 06:04 PM
07/26/08 06:04 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
WOW!
This is why I love MOPARTS.
Lots of options here and lots of good feedback Thanks to all
I've been doing some additional reading on the 6.1 crate motor on a few other threads here and that sounds like a really good deal If the electronics all work out.
While I'm at it what is all of you opinion on an OD automatic trans? plenty of options here as well from a beefed 727 and a Gear Vendors Overdrive, to a TCI 4 speed automatic to the Chrysler 5 speed auto that will require floor surgery in an A Body. any suggestions?
Re: How much horsepower do you really need???? [Re: 70Sbird] #94457
07/26/08 06:25 PM
07/26/08 06:25 PM
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
I would run an overdrive in the demon if i had the money and could get one. Would love to have 3.91s or 4.10s out back all day long
Re: How much horsepower do you really need???? [Re: DemonKyle] #94458
07/26/08 06:28 PM
07/26/08 06:28 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Thats exactly my thoughts as well.
steep gears to get it out of the hole and still cruise at 70 mph at around 2500 rpm!
I'm just not sure which is the best option. I have not been in the market for a trans in about 15 years and things have changed!
Re: How much horsepower do you really need???? [Re: 70Sbird] #94459
07/26/08 07:48 PM
07/26/08 07:48 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
gear and stroke have a relationship too.
you could use a highway gear and let the advantage of the stroke pull you forward. it will work as well as a gear multiplier.
Page 1 of 3 1 2 3
