Hello,
The guy from a shop has offered to me Eddy heads build with Indy valves and Pro comp springs and other performance parts for the same price as the Eddy heads with its original parts.
He says that they had troubles with the eddelbrock valves and these are better.
I asked him if they build these heads in their shop and he replied to me that they come from Indy who buys eddy heads as bare castings and build them with other better parts.
Are somebody running these kind of heads?
Are they really better than the ones with eddy parts?
These are the specs:
1 paar edelbrock performer cylinder head
8 x Ad. valve MPI-V1-27653 - 2,14"
8 x Ex.valve MPI-V1-27656 - 1,81"
ALL-V3-82604 - Spring Cup
ALL-S2-G911 Comp Camps Valve Spring
ALL-R1-82303 7 degree steele retainer
ALL-L3-PF-555-HD 7 dergree locks
ALL-V3-11/32 Valve stem seal
Cylinder Head Style Assembled
Cylinder Head Material Aluminum
Cylinder Head Finish Natural
Combustion Chamber Volume (cc) 84
CNC-Machined Combustion Chamber No
Intake Runner Volume (cc) 210cc
Exhaust Runner Volume (cc) 70cc
CNC-Machined Intake Runner No
CNC-Machined Exhaust Runner No
Combustion Chamber Style Closed chamber
Intake Port Location Standard
Exhaust Port Shape Rectangular
Exhaust Port Location Standard
Intake Valves Included Yes
Intake Valve Diameter (in) 2.140 in.
Exhaust Valves Included Yes
Exhaust Valve Diameter (in) 1.810 in.
Valve Springs Included Yes
Maximum Valve Lift (in) 0.600 in.
Outside Diameter of Outer Spring (in) 1.550 in.
Damper Spring Included No
Number of Springs Per Valve Single
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Valve Stem Seals Included Yes
Valve Stem Seal Style PC seal
Rocker Arm Studs Included No
Rocker Arms Included No
Rocker Arm Nuts Included No
Guideplates Included No
Valve Cover Mounting Style Perimeter bolt
Accessory Bolt Holes Drilled No
Valve Guides Included Yes
Valve Guide Material Manganese bronze
Valve Seats Machined Yes
Valve Seat Machine Style 3-angle
Valve Seat Material Ductile iron
Steam Holes Drilled No
Oiling Style Through head
Machined for O-Ring No
Heat Crossover No
Thanks a lot for your help.
