383 exhaust manifolds #943869
03/06/11 01:44 AM
03/06/11 01:44 AM
Rhode Island
browndevil Offline OP
Rhode Island
I want to put a new exhaust system on my 70 Challenger 383 with auto transmission. I want to get a set of manifolds taht are correct for a challenger. It currently has casting number 2843992/2806900 which are not correct. From what I have been able to gather, it should have 2951865/2899879 but these seem to be harder to find and more expensive. I appears that 3751068/3751071 will also work and these are easier to find and cheaper. I don't require date/numbers matching. What is the physical difference between the two sets? Is it a difference in clocking of the mounting bolts? Any help would be appreciated.
Thanks,
Michael
Re: 383 exhaust manifolds [Re: browndevil] #943870
03/06/11 03:01 AM
03/06/11 03:01 AM
might find some good info at www.bigblockdart.com
Re: 383 exhaust manifolds [Re: browndevil] #943871
03/06/11 12:19 PM
03/06/11 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks,
Michael
If you don't require dates/numbers, and you don't want to have the heat stove, the manifolds you have are the same as either of those other sets you quote , the only difference is the clocking of the flange on the passenger side manifold.
But to answer the other question , no difference in mounting or flange clocking of the other 2 sets .
Cost ... ZERO ....
